Introducing ReCap Pro 2022
What is included in Autodesk ReCap Pro 22.0.0?
New Features:
- Scan-to-mesh cloud service.
- Support project publishing and collaboration through Autodesk connected drive such as Autodesk Drive and Autodesk Docs (BIM 360) via Autodesk Desktop Connector.
- Support opening RealView of ReCap projects with ReCap viewer in Autodesk Drive and Autodesk Docs (BIM 360).
- Support multi-scan selection in project navigator.
- Support exporting panorama images of structured scans.
- Allow users to specify the unit type of the raw scan.
- Support exporting normal information in .pts / .e57 file format.
- Support importing normal information from e57 files.
- Project unit setting can be remembered as default project units and it is applied to applicable ReCap workflows.
Fixed the following issues:
- Improved stability when indexing large scans.
- Improved stability when importing scans.
- Improved stability when registering large number of scans.
- Improved stability when exporting to structured e57 files.
- Improved stability during project optimization.
- Fixed fractional inch display issue.
- Fixed issue that deleted points are still visible after project optimization.
- Corrected security vulnerabilities.
Improvements:
- Performance improvement on loading and editing project with regions.
- Performance improvement on project optimization.
- Improve rendering quality for large projects. More detailed information can be rendered now.
- Updated the .rcc / .rcs file search order to allow files in the same folder as the .rcp file load first.
- Upgraded the Geospatial Coordinate Systems library from 14.07 to 14.08.
Learn more about What's New in ReCap 2022
What is included in ReCap Viewer?
New Features:
- ReCap Viewer is now integrated to Autodesk Drive and BIM 360 (Autodesk Docs). User can publish project using Autodesk Desktop Connector and view ReCap project in https://drive.autodesk.com/ and https://docs.b360.autodesk.com/.
- Support creating and editing annotations such as Note, Measurement, or Markup (only for annotations created via web interface)
- Support adding attachments
- Support creating and updating View State
- Support search among scans, annotations, and View States
Learn more about ReCap Viewer
What is included in Autodesk ReCap Photo 22.0.0?
New Features:
- Support creating new projects through Autodesk connected drive such as Autodesk Drive and Autodesk Docs.
- Remember user's choice of folder selection.
- Fixed issue that project cannot be deleted.
Improvements:
Important Notes:
Installation instructions
You must have administrative privileges on your Microsoft® Windows® operating system to complete the installation process.
Installing Autodesk ReCap / Autodesk ReCap Pro on a single computer:
a. Via Autodesk management portal:
- If you are a subscribed user, log onto your Autodesk account at https://manage.autodesk.com/home/
- For single user installations:
- Look for ReCap Pro in the list of All Products & Services
- Expand ReCap Pro and click on 'Downloads' for 2022.
- Select the preferred download method and language and follow the on-screen instructions.
- For deployments, click on 'Custom Install' and follow the on-screen instructions.
b. Via ReCap product download page:
c. Using Autodesk Desktop App:
- If you have Autodesk Desktop App installed on the machine, it would show ReCap Pro 2022 available for download.
- Press the 'Install' button to install the latest ReCap version
Activation details for subscribers
Please use the user name as mentioned in your subscription. These are also available in your management account at https://manage.autodesk.com/home/
Klarinda Gunadi Widjanarko
Senior Software Engineer
