Hi Everyone,
We are happy to announce that Autodesk ReCap Pro 2025.1 has been released!
What is included in Autodesk ReCap Pro 25.1?
New Features and Improvements:
- Added support for importing panoramic image data from the e57 file.
- Added support for exporting image data to e57 file.
- Added support for exporting a mix of structured scans and unstructured scans to e57 files.
- Added new DeCap command line tool for importing image data from e57 file.
- Added support for 3Dconnexion's SpaceMouse in the main 3D View in perspective and orthographic modes.
- Added support for extended classifications for LAS 1.4 and Point Data Format 6-10.
- Added support to show a Read-Only warning before Manual Classification and Intelligent Decimation operations were performed on no-write access datasets.
- Improved stability when extracting targets.
Bug Fixes:
- Fixed an issue in which intensity from Faro scans were not imported correctly.
- Fixed an issue in which the opacity of the measurement disk for the Distance Tool was increased.
- Fixed an issue in which exporting RealView images for single large scans was closing ReCap silently.
- Fixed an issue in which selecting all points in the canvas using the Selection Tools did not work correctly at times.
- Fixed an issue in which ReCap would stall forever during project launch, returning to the project after registration, and invoking Scan to Mesh or Publish dialogs.
- Fixed an issue in which selected text highlight colors were changed from defaults based on different Windows OS themes.
- Fixed an issue in which the 'None' column for Text options during import was not localized.
- Fixed an issue in which classification information was not being read while importing a text file with classifications in languages other than English.
- Fixed an issue in which target coordinates in the Survey/Target dialog box were converted to exponential formats for languages other than English.
- Fixed an issue in which a Read-Only warning was being shown for classification operations for certain datasets that had full access.
- Fixed security vulnerabilities.
Known Limitations: https://help.autodesk.com/view/RECAP/ENU/?guid=known_issues
Installation Instructions
You must have administrative privileges on your Microsoft® Windows® operating system to complete the installation process.
Updating Autodesk ReCap / Autodesk ReCap Pro on a single computer:
a. Using Autodesk Access:
- Ensure Autodesk ReCap version 25.0.0 is installed on the computer.
- Launch Autodesk Access from the system tray or from Start -> Autodesk -> Autodesk Access.
- ReCap Pro 2025.1 Update should be visible in the list.
- Click on 'Update'. The new update will be downloaded and installed. Autodesk ReCap will be updated to version 25.1.0.
b. Direct download & install:
- Login to Autodesk Account: https://manage.autodesk.com/home/
- Download ReCap Pro 2025.1.0 Update from "Product Updates".
- Double-click on the executable (*.exe) file.
- Follow the installation instructions on the screen. Autodesk ReCap will be updated to version 25.1.0.
What is included in Autodesk ReCap Viewer?
New Improvements:
- Improved Accuracy: Enhances point cloud data and extracted features for more precise measurements and consistent coordinates across cloud and desktop environments.
- Enhanced Point Cloud Rendering Quality: The LOD algorithm has been improved to ensure consistent and optimized rendering quality.
What's New in ReCap Pro
Learn more about E57 File Enhancements
Learn more about 3D Mouse Navigation
Warmest Regards,
Rishov Barman
Reality Capture
