Attach point cloud failed
Light_Guy
Message 1 of 9
Light_Guy
We are currently scanning with the new Faro 330's. We are importing directly to ReCap pro and have had no issues, until we tried to import those projects to AutoCAD and Inventor. When I try to pull them in I get the following error in the command line:
All scans are not found or invalid
Did something change from the beta to the release that I need to update in order for these scans to import? I had no issues bringing in RCP files to ACAD and Inventor with the beta version.
Paul Hamor
Senior Designer/CAD Manager/Data Manager
"Always Good Ships!"
Replies (8)
Message 2 of 9
vidanom
Hi Paul,
We’ll try to investigate and see what has changed.
Do you receive the same error message if you try to import individual .RCS file?
Thank you,
Mitko
Message 3 of 9
Light_Guy
No, the rcs files seem to insert OK in both programs. It is just the RCP files that will not come in.
Paul Hamor
Message 4 of 9
vidanom
Thank you Paul,
I’ll forward the message to the other Teams.
Until then, you can export your projects as Unified .rcs, which will contain all the points from the individual scans and the performance will be much faster when imported in the other products.
Thank you,
Mitko
Message 5 of 9
ryan.frenz
The formats haven't changed.  Have you moved the project, maybe between folders or machines?  Some of the other products handle this in different ways.  If so, try opening & saving the project in ReCap Pro at the new location.  Then try attaching again.
Ryan
Message 6 of 9
Light_Guy
The projects did get moved around some. My IT guy was able to get us the latest version of Standard and that seems to solve the problem, but not until we save the project once with it.
Paul Hamor
Message 7 of 9
ryan.frenz
Thanks for the response, good to know.  You're using 2014 products I assume?
Message 8 of 9
Light_Guy
Yes, Factory Design Suite 2014 (Premium and Ultimate)
Paul Hamor
Message 9 of 9
chandrashekhara.puttegowda
Community Visitor
Community Visitor
For 2016 Version also same error "Attach point cloud failed"
