I've been building a workflow in Google Chrome (54.0.2840.99) and for some reason, changes are not automatically saving; I don't see a way to manually save changes, and even saving a copy of the workflow did not persist the changes. When I restarted the page, my changes were lost. In contrast, when working on the same diagram in Firefox, the workflow is immediately saved upon any changes to a single block.
Solved by nguyenph88. Go to Solution.
Hi @brian.sherman, my apologies for the inconvenience. Praxis automatically saves the workflow when there is a new action on the active workflow. You can see the status message on the top right corner of the workflow when you make any changes. We have a new mechanism and error message system to let user know when there is a connection issue which prevent the workflow from being saved. In this case, i suspect it was due to the connection between components on the workflow. Unfortunately, it's not in production yet but we have a plan to deploy it early.
Again, thank you for your feedback, we really appreciate it!
Thank you,
Peter Nguyen
