Workflow Examples
bagchis
Workflow Examples
bagchis
Hello PRAXIS users,
Sharing an example of a PRAXIS workflow created by Hugo Trépanier. This workflow does a good job of walking a user through the steps required to create a mesh surafce using photos and then coverting it into a surface model using Fusion 360 and Inventor.
https://praxis.autodesk.com/praxis/viewer/cda00f344cbc5c6924c5cdcb2a3b5d53b5a11c98
Great work Hugo!
If you have examples of workflows that you have created using PRAXIS, please feel free to share examples of your work with other PRAXIS users.
Shibai Bagchi
Product Manager
-niels-
Nice example, but i noticed that the tasks that have knowledge pages attached don't show the "i" icon in the lower right.
They did show on my test page when i had one in there, is this user specific?
As feedback i just want to say that i found the "i" icon very useful in recognizing tasks that have more info.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
bagchis
Hi @-niels-,
Good point and thank you for the feedback. To give you some background behind this ... the "i" notification is something we developed recently to give users a quick visual indicator that there is a knowledge page behind a given node in the workflow map. What happened in this case was that this workflow map was created by the author before we implemented the "i" feature, hence it is not showing up in the link below. With our current implementation, what we need this author to do is open the workflow once and make a small edit which will trigger a save of the workflow map. Once this happens, the map will automatically update to show the "i" feature on the given nodes and going forward it will contiue to persist.
Shibai Bagchi
Product Manager
ppscade
I have lastly worked on Visio for the workflow design. I am looking for a solution to Import Visio Workflows into Autodesk PRAXIS.
attached is .vsd ( remove .nwd for use )
