Boolean bugs
Boolean bugs
akcharly
Boolean bugs
akcharly
Hi, dear Project Falcon team
Today, while recording a tutorial, I ran into several bugs, so I’m sharing them with you.
I didn’t re-record the video separately in English, but in the Timing section I commented on everything I was saying while recording the tutorial.
Video - https://www.youtube.com/watch?v=53-2xfh4G1Q
Timing:
0:00 - I show a sped-up process of how I created this object, which caused the bugs.
0:09 - Here I show that one of the cut objects somehow cannot be selected. This is exactly where I mention that it is a strange bug.
0:41 - Then I speed up the process and show that only restarting the software helps me select and delete these objects.
0:46 - Then I speed up the process again to show the further steps that led to even stranger bugs.
0:52 - We can see a bug where the objects do not merge the way I want. For some reason, the normals get inverted.
1:22 - I try using Split instead of Cut.
1:29 - I try using Mirror again.
1:41 - The same strange bug with inverted normals appears again.
1:44 - Then we see an error message, no matter how much I try to complete the operation.
Thank you and have a great day
Best regards,
Andrew.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" повідомленню! | Do you find the posts helpful? "LIKE" these posts!
На ваше запитання відповіли? Натисніть кнопку 'ПРИЙНЯТИ РІШЕННЯ' | Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Андрiй Кривуля | Andrew Krivulya | 3D Grooming Artist - Facebook | Instagram | Twitter | LinkedIN | Youtube | Artstation
joaquim.moral
Hey @akcharly, thanks a lot for all the details and for conducting your review and feedback.
This really helps and support the team in improving the tool 🙂
Best,
Your question got successfully answered? Then just click on the 'Mark as solution'
¿Te ha parecido útil este post? ¡Deja un like!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Joaquim Moral
Senior Community Manager - EMEA / LATAM and Media & Entertainment lead
sroselle
Thanks for reporting this @akcharly.  We will make sure this is logged by our dev team.
akcharly
You're welcome. Glad to be helpful, and I’m glad you’re listening.
akcharly
Awesome! Thank you!
