Printing and Plotting
Post 1 of 14
pdf publish options ignored
451 Views, 13 Replies
05-31-2011 06:44 AM
I am using Autocad 2010, and have upgraded to windows 7.  When I publish to pdf using Dwg to Pdf.pc3, my options (single-sheet file, do not include layers, etc.) are ignored and I always get multi-sheet files with layer information included regardless of what options I select.  Is this a known issue or am I missing something?
Thanks in advance for your help.
PUBLISHCOLLATE variable setting perhaps?
AUTODESK EXPERT ELITE
2285 Kudos
2046 Solutions
Post 2 of 14
Re: pdf publish options ignored
05-31-2011 07:08 AM in reply to: pstarkey
Dean Saadallah
AutoCAD, LT and Architecture User
Blog | Google+ | PINS
Facebook | Twitter | LinkedIn
4 Kudos
1 Solution
Post 3 of 14
04-11-2013 09:03 AM in reply to: pendean
I have the same issue. I am using AutoCAD 2001 with Windows 7 - the PUBLISHCOLLATE is set to 1 and I still get multiple PDF files no matter what I select. I use single-sheet and multiple-sheet and get the same result.
Christina
Christina
Civil 3D 2014 SP2
Windows 7
2285 Kudos
2046 Solutions
Post 4 of 14
04-11-2013 09:21 AM in reply to: ckako301
Do you mean AutoCAD 2011?
Are you using the PUBLISH command's default PDF option? If you select teh default DWF option as a test, does the same problem occur?
Dean Saadallah
4 Kudos
1 Solution
Post 5 of 14
04-11-2013 09:31 AM in reply to: pendean
Oops. Typo. Yep. 2011 Smiley Happy
I am using the publish command... I'm afraid I'm not sure what you mean by the default PDF option. I am utilizing the DWGtoPDF.pc3.
Christina
Christina
Civil 3D 2014 SP2
Windows 7
4 Kudos
1 Solution
Post 6 of 14
04-11-2013 09:55 AM in reply to: ckako301
I see where the option is now! If I publish to PDF instead of the "plotter named in page setup". I tried it with the PDF setting and it still creates multiple PDF files.
Christina
Christina
Civil 3D 2014 SP2
Windows 7
Highlighted
2285 Kudos
2046 Solutions
Post 7 of 14
04-11-2013 10:05 AM in reply to: ckako301
Can youn provide screenshots of the PUBLISH command main pop-up, plus a screenshot of the pop-up after you click the Publish Options button?
Dean Saadallah
4 Kudos
1 Solution
Post 8 of 14
04-11-2013 10:41 AM in reply to: pendean
Hopefully these help Smiley Happy
Christina
Civil 3D 2014 SP2
Windows 7
4 Kudos
1 Solution
Post 9 of 14
04-11-2013 10:43 AM in reply to: ckako301
Forgot one...
Christina
Civil 3D 2014 SP2
Windows 7
2285 Kudos
2046 Solutions
Post 10 of 14
04-12-2013 07:00 AM in reply to: ckako301
You can't use "PLOTTER NAMED IN PAGESETUP", it must only be PDF or DWF if you want the "one file output" to happen.
Your choice of plotter makes no difference, if you want one file output you have to do it the PUBLISH command way and not your way.
Try that, then report back.
Dean Saadallah
