RE-Activation AutoCAD 2005
Hi there,
I need help to reactivate our AutoCAD 2005. Our company has a licence. What options are there?
Is it possible to get an standardcode?
Best regards,
John
Ognyan
There are many things you can do.
1.Call Autodesk by email and demand a new activation key.
2.Activate in offline mode and send them the code and they will send you a response code.
3.(optional)Sue the company if they don't want to help you for the product they took your money?..
4.If you are from Europe, the Directive of the European Parliament and of the Council on the legal protection of computer programs:
https://eur-lex.europa.eu/legal-content/en/TXT/?uri=CELEX:32009L0024
Point 13 clearly says that you can open the software by your own means if the company doesn't provide support.Mainly this line:
''This means that the acts of loading and running necessary for the use of a copy of a program which has been lawfully acquired, and the act of correction of its errors, may not be prohibited by contract.''
So in the European Union, the contract that AD tries to restrict the costumer does not apply as it was voted already in 2009.Ten years before the new invented rules by Autodesk.
5.This is additional option(included for the fanboys that may come), but move to subscription and loose the current software.
Good luck.
pendean
Community Legend
Community Legend
Real answer for today...
Autodesk killed off reauthorizing of 2010 and older software as of August 31 2019, read all about it here https://knowledge.autodesk.com/support/autocad/learn-explore/caas/simplecontent/content/previous-ver...
Sorry, you missed the deadline. There is nothing you can do about it today. If you still have your old Win7 PC and all works well, hang on to it for as long as it will last, then figure out a new option if you are unable to join Autodesk Subscription for newer software.
If you find Autodesk software subscriptions too expensive, there are many other CAD packages out there with no subscription options (initial cost may still be comparably high) that you can go get and use.
