Previous Version Support
Welcome to Autodesk’s Previous Version Support Forums. Share your knowledge, ask questions, and explore Previous Version Support topics.
Question with license error 2013
2 REPLIES 2
adm_tiU5QTW
220 Views, 2 Replies
I had notebook computer with the license AutoCAD 2013, I did the return of license correctly because it was necessary to format it and now I have errors for execute the same license. Anyone can help me? Please.
I put the error in attached.
Tags (1)
Labels (1)
2 REPLIES 2
paullimapa
in reply to: adm_tiU5QTW
Your AutoCAD version is so old Autodesk will no longer activate your license. You may want to try contacting them directly to see if the will respond. https://www.autodesk.com/support/contact-support?&utm_medium=cpc&utm_source=google&utm_campaign=&utm...
Paul Li
IT Specialist
@The Office
it tells you what the issue is
go through this: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Top-Five-Reasons-W...
then contact your reseller to verify your serial number if it was upgraded to something else you can no longer use 2013
Administrator Productivity
