Previous Version Support
Welcome to Autodesk’s Previous Version Support Forums. Share your knowledge, ask questions, and explore Previous Version Support topics.
I want to buy Autocad 2014 because of the compatibility of program
2 REPLIES 2
tpgh0826
380 Views, 2 Replies
Can I buy the Autocad 2014?
I have to use Autocad 2014 for the compatibility of program. This program is supported from versions 2014 and earlier.
Please let me know the method to use Autocad 2014
Tags (1)
2 REPLIES 2
Kent1Cooper
in reply to: tpgh0826
You won't be able to buy Acad2014.  But you can draw things in any newer version, and SAVEAS them back to earlier formats for compatibility.   Or you can use the free DWG TrueView program to convert newer-format drawings to earlier formats.  [You may lose certain things or some properties of things made with newer features of the software that are not part of the older version.]
Kent Cooper, AIA
paullimapa
That old version has not been sold for almost a decade. Autodesk only sells the latest version 2024 and that’s based on a subscription pricing structure:
https://www.autodesk.com/products
But once you’re on subscription then you can have access to 5 versions back which would bring it as far back as 2019. Any versions older than that would require you to contact Autodesk directly.
Paul Li
IT Specialist
@The Office
Administrator Productivity
