Previous Version Support
Welcome to Autodesk’s Previous Version Support Forums. Share your knowledge, ask questions, and explore Previous Version Support topics.
Getting AutoCAD Architecture 2013 to run window 10 os?
2 REPLIES 2
info
300 Views, 2 Replies
I believe that I have addressed the major glitches. Just tried plotting and ACA just shut down? reopened and for the umpteen time recovered the files, I was working on?
Does anyone have some insight?
Tags (1)
2 REPLIES 2
pendean
in reply to: info
First read this http://autode.sk/1IY4C2X
Then ensure you have all the ACA2013 updates installed https://knowledge.autodesk.com/support/autocad-architecture/downloads/caas/downloads/content/autocad...
if you are still having issues the try these tips How to Make Old Programs Work on Windows 10
and FIX: AutoCad not Working in Windows 10
If none of the above work, your printer/plotter driver is not compatible with the new setup, go find alternates.
info
in reply to: pendean
Thank you to everyone that replied and provided insight and suggestions. I am up and running everything is stable and working as expected.
Administrator Productivity
