Previous Version Support
Welcome to Autodesk’s Previous Version Support Forums. Share your knowledge, ask questions, and explore Previous Version Support topics.
Autodesk Civil 3D 2003: How to dock and lock the command line?
4 REPLIES 4
ghernandezJPLSS
215 Views, 4 Replies
***THE POST TITLE HAS BEEN EDITED FOR CLARITY***
Tags (1)
4 REPLIES 4
Hi @ghernandezJPLSS !
Is it really 2003? Well, try to drag the command line to where you want it. Then, use the command "LOCKUI" and press "2" to lock the position. Like this: https://www.youtube.com/watch?v=l11dVbXP-Mc.
[PT-BR] Se essa postagem foi útil para você, clique em Curtir! Se a resposta resolveu o seu problema, clique em Aceitar Solução.
[EN-US] If it was helpful to you, click on Like! If the answer solved your problem, click on Accept Solution.
Matheus Lima
Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager | Instagram @bim_infra | LinkedIn
Civil 3D didn't exist until 2005, so your probably using Land Desktop and while that should be easy to achieve, you'd probably need to be running Windows XP or one of its variants before 7. If you're running one of those platforms, and it's from 2003, I do believe that's a few to many years and beers for me to help. Sorry.
Rick Jackson
Survey CAD Technician VI
Elina.P
in reply to: ghernandezJPLSS
Hey @ghernandezJPLSS!
Here are some tips for docking the command line:
How to dock the command line outside of AutoCAD
Command line moves from the position after restarting Civil 3D
Command line moves or does not hold a position in AutoCAD and Civil 3D
Let us know if any of the articles helped you!
It would be useful if you Accept the Solution which helped you to resolve the issue, co that other users can use this knowledge as well:)
Elina P.
Technical Support Specialist
Civil Engineering Solutions
Administrator Productivity
