AutoCad LT 2008 activation error
ur_ranjith
ur_ranjith
Activation does not succeed for AutoCAD LT 2008.
Valentin_CAD
@ur_ranjith ,
Check these links for as additional resource:
https://knowledge.autodesk.com/customer-service/download-install?_ga=2.116416067.439615868.162903941...
https://forums.autodesk.com/t5/installation-licensing/bd-p/24
https://forums.autodesk.com/t5/autocad-lt/ct-p/2000
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
ur_ranjith
Try to offline method but not received the activation code.
RobDraw
Autodesk stopped generating activation codes. Read similar threads in this forum for additional information.
Rob
pendean
Community Legend
Community Legend
Activation of AutoCAD version 2010 and older are no longer possible: Autodesk pulled the plug on those servers.
You are just out of luck. Sorry. Read this entire forum dedicated to the topic to see for yourself.
