Previous Version Support
Welcome to Autodesk’s Previous Version Support Forums. Share your knowledge, ask questions, and explore Previous Version Support topics.
AutoCAD 2016 setup file
3 REPLIES 3
689 Views, 3 Replies
I can't find the 2016 autoCAD install. I have a license, but I can't use the 2016 version because it can't download it.
HELP
Tags (2)
Labels (1)
3 REPLIES 3
Alfred.NESWADBA
if you have 2016 as active version (and it's not updated or you are not on subscription) then you should find it inside https://manage.autodesk.com
If you have an active subscription, then you have AutoCAD 2022 and 3 releases back in this portal, but 2016 is then out of your active licenses.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
I have a 2016 autocad activation code. I cannot define this Code to user. If I can install the autoCAD 2016 original setup file, I will write my code in the serial-code section and use it. That's how I did Revit 2016. Someone shared the Revit 2016 installer on the forum. Can you share the AutoCAD 2016 setup file with me?
Alfred.NESWADBA
An activation code is bound to a serial number and to specific hardware.
If you have a new computer or an updated operating system or some parts inside the computer changed, this code does not work, you need a new one.
Having an activation code does not mean you have a valid license.
Again, the download of the setup's can be found in https://manage.autodesk.com
You might also "ask" Autodesk AVA here: https://ava.autodesk.com
- alfred -
Alfred NESWADBA
Administrator Productivity
