Previous Version Support
Welcome to Autodesk’s Previous Version Support Forums. Share your knowledge, ask questions, and explore Previous Version Support topics.
Autocad 2007 LT - Error AutoCAD is not installed properly
10 REPLIES 10
Message 1 of 11
rcusa_tech
2623 Views, 10 Replies
Hello
I am receiving the error
This version of AutoCAD was not installed properly and some features may not run correctly. You should reinstall AutoCAD immediately to make sure all features are working properly. Do you wish to continue anyway
I have looked at the Fix for not installed from the Autodesk forums.  We have only .Net Framework 1.1 and .Net Framework 2.0 installed on this new laptop, as was the previous laptop that worked fine with Autocad LT 2007.
I am still getting this error and unable to get it resolved.  I have checked the registery part of the kb article and it does not have a content type.
Suggestions on where to go from here.
Tags (1)
10 REPLIES 10
Message 2 of 11
rcusa_tech
in reply to: rcusa_tech
after about 10 days this error has appeared again.
I thought I had it resolved by uninstalling .Net Framework 2.0 service pack 2 and installing just the .Net Framework 2.0 original, but no such luck.
As I look at our other machines they all have varying versions of .Net Framework installed on them, so I don't think this is a .Net Framework issue
Anyone with suggestions, what has worked in the past for others?
Message 3 of 11
rgd
Observer
Did you manage to resolve this issue
I have the same problem and tried the solutions to no avail
Message 4 of 11
Charles_Shade
in reply to: rgd
.NET issues can be tricky.
rgd - Are you on the LT 2007 platform as well?
And is removing and reinstalling .NET 2.0 what you have tried?
Or what have you tried?
Message 5 of 11
rgd
Observer
in reply to: Charles_Shade
Autocad 2005
Trying all the .net remedies
No luck as yet
Trying something else as I write
Let you know if successfull
Message 6 of 11
rgd
Observer
in reply to: rgd
ok
Problem solved by my technician
find
dotnetfx_cleanup_tool.zip
run the .exe
Re-install
.netfx.exe
Worked for me
Message 7 of 11
drjohn
in reply to: rgd
Message 8 of 11
Charles_Shade
in reply to: rgd
Excellent. Thanks for the follow up and solution.
And DJ too!
Message 9 of 11
rgd
Observer
let me know if you succeed
Message 10 of 11
ludaala
Message 11 of 11
Sjopar
When I try to install the LT 2007 I get a message that NET is not installd. Autocad 2007 LT cannot be installed without this component. What to do?
//Par
Administrator Productivity
