Install 32-bit 2008 on 64-bit win10
Joe-Bouza
Mentor Mentor
Message 1 of 11
Joe-Bouza
Is this possible? we tried all the windows work arounds and HP support said..."probably not"
Joe Bouza
Replies (10)
Message 2 of 11
pendean
Community Legend
Community Legend
Bored? Or trying to get around a licensing issue temporarily 😉
What did you try? or would you like everyone to regurgitate all of those back to you so you can spend hours/days saying "...already tried that..."?
Message 3 of 11
DarrenP
this worked back in the day: https://forums.autodesk.com/t5/autocad-architecture-forum/updated-workaround-instructions-for-64-bit...
DarrenP
Message 4 of 11
RobDraw
What are going to do when you need an activation code?
Rob
Message 5 of 11
Joe-Bouza
Asking for a friend. I know it makes no sense
Joe Bouza
Message 6 of 11
Joe-Bouza
Pardon for wasting time. I did nothing. I'm looking for a friend. WHAT I know is he tried what ever Google  recommended
https://www.google.com/search?q=install+32+bit+on+64+bit&rlz=1C1OKWM_enUS922US922&oq=Install+&aqs=ch...
Joe Bouza
Message 7 of 11
DarrenP
what i posted should still work if you can find the Orca tool that is mentioned
DarrenP
Message 8 of 11
m_latz
Here you can download a "patch" to adapt the installation sources to install on 64-Bit OS. This "Patch" copies a transformation to the original installation source and modifies the setup.ini file.
This is easier if the user is not familiar with orca. And here is the explanation. It is in german, but you can tranlate with your browser.
regards
Markus
Message 9 of 11
RobDraw
Is that bug elephant I'm seeing not so looming as I think it is?
How is activation going to happen?
Rob
Message 10 of 11
m_latz
This does nothing else as that you can install AutoCAD 2008 32-Bit on a 64-Bit OS. Everything else is out of the scope !
regards
Markus
Message 11 of 11
Joe-Bouza
We will give it a try
thanks
Joe Bouza
