acad r 14 questions forum
Message 1 of 33
hi all,
we have some old school needs and would like to post some questions related to r14. can anyone suggest a place to post such questions?
thanks in advance.
Replies (32)
Message 2 of 33
ara_neresesian
Hi
I think this is only place which you can ask
Just ask what you want.
And i am sure you will have your answer.
Good luck
Message 3 of 33
imadHabash
Hi and Welcome to AutoDesk Forum,
Lately all AutoCAD releases forums combine in this forum,please post your issue and help will come to you.
Imad Habash
Message 4 of 33
hi guys,
thanks a lot.
we are looking to get an "optimal" PC desktop to handle acad r14. some suggestions have been a Precision Workstation or an Optiplex 580 tower - with an additional suggestion to get an intel core 2 duo or a dual core processor. 4 GB RAM and 256 GPU with possibility to upgrade to 1 GB GPU. i am not a technical computer guy so i am trying to forward a specific machine with specific specs.
we had a machine that went south and we'd like to replace this installation. any suggestions on where to get help on this would be welcome.
we don't want to get into debates about why upgrading to newer software is advisable and we have discussed this with our software vendor.
TIA
Message 5 of 33
Alfred.NESWADBA
I guess AutoCAD R14 works on all workstations which are something like "modern". The system resources from the time of 1998 were much, much lower than any basic software developed today. So take anything and it will work a lot faster than a highest end workstation from 1998+/-.
What I would take care of:
  • I don't know, which of the current operating systems can run AutoCAD R14, I'm not sure, if you might have troubles with that.
  • Especially take care about the hardware lock (if you have one), so you need a parallel port/Centronics interface and you might need special drivers to get the interface running with the operating system, and to get AutoCAD working with that interface. That can be really tricky.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 6 of 33
chriscowgill7373
I agree with the above, any tech that is out there now ought to be more than enough to run R14, the downside, it may be too much.  You may be into an uphill battle,  Autodesk has stated that they will not be providing support to anything lower than 2013 on Windows 10, so if you have Windows 10 on this machine, R14 may not even function, and if it does, could be subject to errors and worse yet, Autodesk support wont be able to help you on it.  You could try compatibility mode, but Windows 10 only has compatibility mode back to Vista.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Window...
Oh the days:
System Requirements
  • Min Processor Type
    Intel Pentium
  • Min RAM Size
    32 MB
  • Min Hard Drive Space
    50 MB
  • OS Required
    Microsoft Windows 95, Microsoft Windows 98, Microsoft Windows NT 3.51 or later
  • OS Family
    Windows
  • Additional Requirements
    CD-ROM, SVGA monitor, mouse or compatible device
    Intel Pentium
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
Message 7 of 33
TheCADnoob
There is no need to go new. I would be tempted to by another model just like your old PC. just google the setup you are trying to replace. you can find older PCs refurbished and for the price of a new PC you could probably by 3 to 4 replacement PCs. They run cheap like below $50.
Just shop you current setup and look for a refurbished machine. If you dont want to upgrade the software, there is no sense in upgrading the PC especially when the price is sooo cheap for those pcs.
CADnoob
Message 8 of 33
hi TCn, all. so we will be running XP. i was hoping a specific dell recommendation with specifications so i could pass it along. i am only seeing the optiplex with AMD processors and it was advised to go intel. also i don't know whether the optiplex 580 is a good machine. the used PC place can /upgrade/ it but i was hoping to pass along specs for what we need since they have nothing in stock... thanks
Message 9 of 33
current setup crashed but was in a boot camp type installation on a mac as far as i remember and our tech moved out of state...
Message 10 of 33
chriscowgill7373
if you're buying a modern machine, AMD or Intel are not going to matter much when it comes to running R14, they are both way more processor than what is required to run the software.
Message 11 of 33
you are suggesting buying a newer pc desktop and running windows xp on it?
Message 12 of 33
chriscowgill7373
no, I was just stating that if that is what you had decided to do that AMD vs Intel wont matter much.
I agree with @TheCADnoob up above, I'd recommend seeing if you can find an older machine that more closely meets the specs of what you actually need, less likelihood of issues with tech that is too modern.
Message 13 of 33
hi. this is the point of the post. i am trying to get specifications for s specific machine that is well regarded for running cad in an office environment.
this is what i am trying to find since our tech guy is no longer here.
intel versus amd i suppose could be debated but as i stated it has been suggested we go with intel...
Message 14 of 33
chriscowgill7373
To run modern CAD is completely different than running a cad program that was released almost 20 years ago.  You cant run them both on the same machine is the basic jest of what we are trying to say.  In 1997 they didn't even probably dream of a 64 bit processor, or that one would ever need 32 GB of ram on a machine.
The specs for R14:
System Requirements
    Intel Pentium
  • Min RAM Size
    32 MB
    50 MB
  • OS Required
  • OS Family
    Windows
    Intel Pentium
The specs for 2018:
System requirements for AutoCAD 2018
Operating System
  • Microsoft® Windows® 7 SP1 (32-bit & 64-bit)
  • Microsoft Windows 8.1 with Update KB2919355 (32-bit & 64-bit)
  • Microsoft Windows 10 (64-bit only)
CPU Type 32-bit: 1 gigahertz (GHz) or faster 32-bit (x86) processor
64-bit: 1 gigahertz (GHz) or faster 64-bit (x64) processor
Memory 32-bit: 2 GB (4 GB recommended)
64-bit: 4 GB (8 GB recommended)
Display Resolution Conventional Displays:
1360 x 768 (1920 x 1080 recommended) with True Color
High Resolution & 4K Displays:
Resolutions up to 3840 x 2160 supported on Windows 10, 64 bit systems (with capable display card)
Display Card Windows display adapter capable of 1360 x 768 with True Color capabilities and DirectX® 9 ¹. DirectX 11 compliant card recommended.
¹ DirectX 9 recommended by supported OS
Disk Space Installation 4.0 GB
Browser Windows Internet Explorer® 11 or later
Network Deployment via Deployment Wizard.
The license server and all workstations that will run applications dependent on network licensing must run TCP/IP protocol.
Either Microsoft® or Novell TCP/IP protocol stacks are acceptable. Primary login on workstations may be Netware or Windows.
In addition to operating systems supported for the application, the license server will run on the Windows Server® 2012, Windows Server 2012 R2, Windows Server 2008, Windows 2008 R2 Server editions.
Citrix® XenApp™ 7.6, Citrix® XenDesktop™ 7.6.
Pointing Device MS-Mouse compliant
Digitizer WINTAB support
Media (DVD) Download or installation from DVD
ToolClips Media Player Adobe Flash Player v10 or up
.NET Framework .NET Framework Version 4.6
Message 15 of 33
Alfred.NESWADBA
Well, maybe the workstation runs with Windows 10 and AutoCAD R14 runs within a virtual system like Oracle VirtualBox or VmWare Player (also in that case, take care about the hardware lock as virtual systems might not find a parallel port).
- allfred -
Alfred NESWADBA
Message 16 of 33
chriscowgill7373
valid point, good luck finding a modern machine that has a parallel or even a serial port on it these days.
Message 17 of 33
hi. just trying to stay on point. we don't want to run a vm. we are looking for specs for a native install. perhaps there is a better forum for this?
seems weird to mash all of acad world into one forum. makes getting specific information pretty difficult...
Message 18 of 33
chriscowgill7373
On topic:
Minimum specs for a native install are above.
Off topic:
As for the forum, I dont know that there would be very much traffic, I'm not sure how many people out there are still using R14, the OS (Windows 95/98/NT) has been gone for a long time.  I havent had a machine with less than 512 mb of ram in probably 10-15 years.  There are quite a few AutoCAD forums, this is the only one I visit besides the Civil 3D one.  I dont have time to keep tabs on that many locations.
Message 19 of 33
thanks. i wonder if someone can suggest a good place to post the question.
Message 20 of 33
You might try CadTutor
I ran R14 on Windows 7 for a long time. It took several days worth of hacking the registry to get it working and then there were a few things that didn't work as they should have.
My guess is getting it to work on Windows 10 would be a tough task, but if you're up to the challenge go for it. Not ideal but XP on a VM might be your best option.
