Alright everyone who’s bent on metal listen up! We’re conducting a limited preview of our new sheet metal functionality. The goal of this preview is to allow our community to provide valuable initial feedback, allowing us time to make the necessary changes, while the team continues to work on the rest of the features that will be in our first release. In this forum we will discuss your sheet metal workflows, capture feedback and provide instructions. The number of users we bring into the preview is limited, but it will grow as we get closer to the release. If you would like to be considered for participation, please email me at mike.prom@autodesk.com
For our first release of sheet metal we needed to pick a starting point. After interviewing customers, industry experts, reviewing feedback from community and using our expertise in this subject matter we came up with the following functionality requirements for our initial release:
In our January 19th update we have include the functionality (turned off by default) that we have completed up to this point for creating a sheet metal part. Meanwhile, the team continues working on our flattening functionality. Numbers 1-4 from above are implemented and we’re looking for your feedback on how you use them in your workflows!
What we are working on
What we do not have
After our first release, there are two more workflows that are planned. The next target will be to use and flatten other CAD sheet metal models. Users have expressed the need to be able to reuse designs they have already created. Once completed the team will work on the ability to convert a model to sheet metal. This will include the ability to start with a solid, shell, and cut the model into different components. There may be other features added along the way based off of feedback we get from users like you.
Most importantly, we’re looking for feedback on how you use sheet metal in your everyday modeling workflows. But, along with how you use sheet metal for your business, please consider creating the parts documented in up coming threads as a way to see how different users approach the same design.
This part is important - there is no guarantee that the models you make now will function properly once sheet metal is fully released later this year. Please consider this when utilizing your time testing this functionality.
The data the is being created for those who are in preview is based off of a branch that the team had and was integrated into production. During preview we are not doing constant updates do to the amount of time require would delay our release. Because of this, we cannot guarantee that designs created in preview will work once fully released into production. Most likely everything will be fine, but this should be taken into consideration when you dedicate your time to the preview. I appreciate everyone's willingness to participate, value your time and want to make sure expectations are clear.
Cheers,
Mike Prom
I believe that position is fine, I just want to know what happen when it comes that the design in preview doesn't work. Will it be translated into a dumb Fusion model (meaning it loses the flattening ability and future SM modifications) or it'll be deleted.
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
We will not delete any data that you create and I honestly do not know if there is an issue what the result of the files will be (corrupt or non-intelligent). If you would like to set up some time to talk about your concerns please send me an email and we can schedule a time.
Mike Prom
Creating a flange is removing the rounded edge
Aah, if it comes to that where the preview files will not work in the released version. I guess the workaround would be to export the SM part as a STEP file and then reimport it back into Fusion as a dumb solid.
Omar Tan
Malaysia
Thanks for the info, great function. At the moment I have interest using the SM fuction to use for our bending machine. Can I please join the beta?
Thanks in advance!
@Anonymous,
I have started a thread for people to provide their information to sign up for a preview.
I will add you to my waiting list.
Cheers,
Mike Prom
I don't have the beta... yet. I don't/haven't seen if there is the ability to create a sheet metal part from a contour sketch (contour flange). Is this available?
Yes this is included. Here is a blog post from several months ago showing the basic functionality
http://www.autodesk.com/products/fusion-360/blog/fusion-forecast-sheetmetal/
Hope that helps
Thank you to those of you that have responded to this thread with feedback on sheet metal preview technology. Your information has been captured and in an effort to improve my responses, I will be closing this thread and going forward we will use the following post.
https://forums.autodesk.com/t5/preview-functionality/sheet-metal-getting-started/td-p/6932660
Cheers,
Mike Prom
