Thank you for your interest in helping us develop the tools for the future of design to manufacturing. Technology previews gather customer feedback around business goal/objectives that the new functionality intends to solve, while the development approaches release. Each preview will start with a small group of users invited, and we’ll continue to expand based off feedback and community interest. The information you provide will be used to ensure we’re reaching our target audience, gathering feedback from diverse backgrounds and experience levels.
Please respond to this thread with the following details and you’ll be added to the list of users we pull from with each new preview:
This part is important - there is no guarantee that the models you make now will function properly once the preview technology is fully released. Please consider this when utilizing your time testing this functionality.
Solved by promm. Go to Solution.
There is an option when you post (email me when someone replies) as seen in the image below. If you forgot to do this or would like to stop getting the emails you can unsubscribe under options.
Cheers,
Mike Prom
Thank you everyone who has responded to this thread for your interest is sheet metal. I have added you to my list of users who are willing to spend some time using the new sheet metal functionality. Each week I will be adding more people from my list to our limited preview based off of the current testers feedback. Once you get added you will receive an email giving more details.
Cheers,
Mike Prom
Products! Large, small, mechanical, static. All sort of products, specifically consumer based.
Sheet metal is important for creating parts within a family of products that are interchangeable. Sheet metal is something that is also nice to use for furniture design.
Creating patterned surface that can be bent or warped and manipulated, especially in terms of seat pans and chair brackets, will speed up the process to get plans to a manufacturer!
-Previous CAD/CAM/DCC experience.
Rhino 3D, Solidworks, Onshape, V-Crave, CorelDraw, Photoshop, Sketchbook.
-What do you typically model / design?
Retail equipment (POS displays, shop fittings, signage, BTL)
-What about the technology preview got your interest?
Browser Access and Sheet Metal
-How do you believe the feature / function that is being previewed will improve your workflow?
For SM the reasons are similar to @clickdraw has, it's common and very useful to design part made of foldable materials (sheets of plastics) with the use of SM modules, to get both 3D model and flat pattern at the same time.
Eventually, I would like to switch to Linux over Windows for my personal use, browser access is the only way. I would like to know if such workflow is feasible for me.
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
Excellent, I look forward to hearing from you and being able to try out the new features (And hopefully give lots of useful feedback as well)
I have two seats and would like to preview the sheetmetal functionality.
I have 20 years experience in architectural sheetmetal design and manufacturing using both Solid Edge and Solidworks.
I am designing and creating manufacturing drawing for architectural special metals and other product design projects.
I have been waiting to preview the sheetmetal capabilities since reviewing Fusion as 90% of my work uses sheetmetal parts.
I won't know until I have a chance to try a few parts to test the work flow and how I might be able to streamline production of manufacturing drawing and flat patterns which often require making repetitive copies of parts and making changes to the models and updating forming drawings quickly.
Thank you for your consideration.
David Bigham
MetalOx Design
Previous CAD experience?
- He utilizado los siguientes programas cad: Autocad 2d/3d, Autocad Inventor, Sketchup, Nano Cad, DesignSpark, Via Punch, Lbre Cad 2d, Qcad... Se que he trabajado con algunos mas.
Con el programa que mas he trabajado a sido con Freecad durante 4 años.
Varias cosa en parametrico. Cosas como carcasas para modulos electronicos, Herramientas como soportes de otras herramientas, Productos ya contruidos. Los dibujo para hacer foto realismo con ellos y hacer presentaciones digitales, Piezas imprimidas que me pide la gente.
Yo me muevo en un ambiente casero.
Realmente mi herramienta de trabajo es Freecad (Modelado 3d parametrico), Siempre he tenido mucha curiosidad por encontrar la herramienta perfecta para mi y la encontre (Autocad Inventor)
mi problema es que no estaba dispuesto a emplear una herramienta de forma ilegal ya que no puedo pagar la suscripcion.y encontré Fusion 360.
Un programa con todo en uno, como Autocad Inventor(2d, 3d, parametrico, animacion, simulacion, render, mesh, sheet metal... y con muchas mas herramientas.
Mi problema en económico...
Así que al encontrar Fusion 360 se me ilumino el camino ya que puedo pagar una suscripción mensual con acceso al programa. Y me encanta el concepto online/offline y la fusion de las herramientas y para poder llevar acabo mis pequeños trabajos y ahorrar mucho tiempo el probar y utilizar las futuras caracteristicas como sheet metal me vendría genial.
Diseños que suelo hacer como plegados en chapa, cajas de cartón, cajas imprimidas en 3d. La Función sheet metal me ayudaría plasmando mis idean en mucho menos tiempo y ayudándome diseñando de otro modo. Me encanta el poder probar las futuras herramientas. Gracias equipo Fusion 360.
Vectric products V carve pro, cut2D, photo vcarve, Sketchup, Artcam and quite a few others
Furniture, cabinet making, advertising products, signs Disability aides, wheelchair manual and electric addon's
Having a browser based cad program so I have the ability to pull my phone out or tablet and wack out a ruff model of something for a Disabled person or a sign, cabinet what ever easily in front of the person anywhere.
Make it easier to get stuff done where there is only cellphone coverage and no internet (we have 4G and fast internet in NZ)
Hi ,
Best Regards,
Ali
Hello promm
My name is Sami.
I an a new to CAD, only about 2 years experience mostly in Fusion 360 and pen and paper. However I have about 20+ year experience in designing software and user experiences.
i design part for my son seating, wheelchair, and other accessibility needs.
I have lost of user experience/software testing in my background. I am not a pro at CAD and while at the surface this makes me seem like the wrong candidate to test, i do not bring a lot of other perspectives to the table, it will either work or not for me, it will either flow or not.
in terms of sheet metal in particular, the functionality will allow me to expand my designs and allow me to make more complex shapes out of flat stock. my most pressing need is a chip tray for new cnc mill. most mills are not accessible via wheelchair so i am having to design a stand and chip tray.
I'd like to use the sheet metal modeler. I have more than 30 years experience with 3d cad, including 8 years with ProE, where I used the sheet metal modeler. Let me know how I can contribute to the Fusion development for sheet metal.
Mechanical:
Autodesk Inventor 2010 - 2016
Fusion 360 since early 2016.
Schematic capture & PCB design:
Cadsoft EAGLE (now Autodesk EAGLE) v4 - v7.
Some KiCAD, some Altium Designer
Mentor for FIRST robotics teams, I model mechanisms and chassis designs to overcome various mechatronics related challenges with the teams I help. I also machine parts for some teams at home (manual lathe, working on a CNC retrofit of my mill). I also design simple workshop tools.
Sheet metal - I miss this functionality from Inventor.
From what I see from posts of the design preview, the sheet metal environment will save manual calculations of bend radii, and help accelerate design by generating a flat layout. These are features I would very much like to test early and promote to my team (FRC#4802) who are just starting to learn about sheet metal.
Thanks in advance,
Adam
I am using AutoCAD software only to design sheet metal parts since last 15 years.
I am sheet metal fabrication business and engaged in manufacturing Control Panels, Machine Enclosures, Acoustic ( Sound Proof) Enclosures, Girder Casting Structures for flyovers and overhead bridges, Lamp Covers and other sheet metal components.
Creating 2D model in AutoCad requires lot off imagination and thinking.
If Any part having multiple bends then it’s become more difficult. For production it require development (unfold size) & Notching has to be done at corners of tray/panels.
Whereas 3D modelling with fusion 360 life will be more easy if we add development feature.
1)Creating 3D model well before actual production will help customers to visualise there finished product in advance which will increase the chances of getting more orders.
e.g. control panel is assembly of left panel, right panel ,top panel, bottom panel, front door and back door. With fusion 360 I can create all 6 panels independently and can assemble it. Which will give clear idea to customer how it will look? From front,back,top,bottom, Left and right side. And many more
2) Also advance feature like development of sheet metal part ( unfold view) will save our time in calculating it.
e.g. to manufacture formed C section of size 100 x 200 x 100mm out of 2mm thick sheet of length 500 mm require 392 mm x 500 mm x 2 mm thk size sheet.
When we will create 3D model of that C section and clicking unfold view it will show me directly plain sheet ( with holes if any ) of size 392 x 500 x 2 mm. no need t calculate it again and this will help correct sizing without manual errors and with folding lines. Easy for production.
with best regards
abhijeet
Previous CAD experience.
- 2 years of Autocad, 6 years Altium, 8 years Solidworks.
- Drivetrains, electric components.
- Sheet metal, molding.
- can't do most work without sheet metal or molding. Just can't.
I worked for five years with Solid Works, mostly sheet metal, but also mechanical and FE analysis in an engineering department.
In the past I designed sheet metal parts for various apparatus, mostly trucks, fire trucks, ambulances, and gravel trucks.
I am currently mulling about creating replacement parts for a hobby car and sharing the files I create open source to help others with hard to find or discontinued parts.
I believe it will make designing sheet metal parts much much quicker and easier than it currently is.
