Fusion IB Arc Slot bugs.
HughesTooling
Consultant Consultant
HughesTooling
I see we have a new toy before the desktop versionSmiley Happy! I found a couple of odd things going on with it though. First it doesn't work sometimes and you're left with some grey arcs you can't delete. I show the problem in the screencast but I'm still not sure why it failed at the start. Second problem is constraining the slot with an angle constraint, also in the screencast.
Mark
Edit While waiting for the screencast I experimented a bit more and found Arc Slot fails if you start a new document and try and use it in the first sketch.
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Something odd goes on in the screencast around 4.40, I change the angle and the coincident constraint between the circle and the origin is removed or ignored!
Mark
Mark Hughes
JasonBrynfordJones
Hi Mark
Thanks again for your feedback, this screencast is super helpful.
A couple of the issues are known, but I will add the rest.  Look out for future updates which might refer to these fixes.
Cheers
Jason
