by accident I turned on branches for one project
now I am stuck with the master and test branch
like with other versioning systems you should be able to also get rid of branches or
if later not needed terminate the branches while keeping the master
Also before turning on a branch Fusion should tell the user that currently this cannot
be undone! I have to be very careful now how I operate in this project.
I think I will at the end export / move all files out and make a new project for Wayne State.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
@skylord73 very true!
Claas Kuhnen
I just also noticed some shortcomings in the file management of the A360 system refusing to move copy download files so I cannot even really migrate the files from that project.
This makes the Undo or cancel branch option even more important!
Claas Kuhnen
I'm moving this to the branch and merge preview forum for appropriate visibility.
What's also frustrating ist that you cannot drop files you don't need when you merge back into master. You can only uncheck them.
The branch you've created lives on even when you delete the files after the merge. Fusion even states no difference looking that the project history.
So there's no way to get rid of a finished then superflous branch. It makes a Project look very messy when you're able to access all branches that ever existed.
Thanks for you post.
You're right. Be unable to delete branch is very annoying.
Branch deletion has very high priority for us and it's something we want to provide very soon.
So please, stay tuned:)
Kamil
In some systems keeping every branch for all time is a feature that is very desired. Perhaps hiding, or archiving a branch would offer the solution you are looking for? It would let you clean up the project history but would also allow you to keep historical branches and the record of the work that was done in that branch.
I agree that we should allow deleting a branch if it was a mistake but deleting a branch where work was done and merged into main would be rewriting history, you would loose track of the activity and not be able to trace the origin of changes and versions. Perhaps this is something not important to a single user, but in teams this could be very important. Thoughts?
Many thanks @kamil.ignac!
@schneik-adsk, I fully agree. We heavily rely on Git here at our company.
Branches that are merged back into master should not be deleted as they represent successful work at that time.
Experimental branches are usually axed here. Regarding what I experienced with Fusion: I finished a feature branch and along the way I created experimental models that are not needed in the master branch nor anywhere else. I would want them to be deleted or at least have the option to on merge so the complete branch is mergerd/closed/history. I thought I could do so that's why I didn't delete them before merging.
Maybe that helps for feature decision: http://ndpsoftware.com/git-cheatsheet.html#loc=;
@schneik-adsk Off topic: I see you're using a MacBook Pro. When was it released and how is the performance Fusion wise, if you don't mind my asking.
I think once delete and trash gets implemented would be able to delete items and branches that are not important so i think we have your need in our backlog.
as to the mackbook...
MacBook Pro "Core i7" 3.1 13" Early 2015 | 3.1 GHz Core i7 (I7-5557U) |
I'm very happy with it. I rarely run it in full retina resolution which i believe is often behind users having issues with fusion on mac book pro laptops. I work with small to medium assemblies and switch between mobile and docked with a 27" display often.
I'll be waiting for the processor upgrade before seriously looking at the new mac books. I might look at 15" again but it will ahve to be super compelling for me to move off the 13" form factor. Its very nice.
cheers
I would like to have both delete and archive as options. I have a few accidental branches that are essentially wasted space, and others that are now dead ends, but I would like to keep the ideas/data for possible re-visitation at a later date.
That is the way I envision it. Archived would be, well, archived (compacted and minimized) as far as storage space and visually in the branch dialogs. Deleted is gone forever with perhaps an undo during a current session. Once you close Fusion, it's gone.
Nick
