Is it the same as this one.
https://forums.autodesk.com/t5/preview-functionality/fusion-ib-arc-slot-bugs/td-p/6916108
How many more guesses do I get?
Mark
Mark Hughes
Owner, Hughes Tooling
Seems to be a problem selecting any point including the origin.
Mark
Mark Hughes
Hi Guys
Good find, thanks for spotting that.
I have added the issue FZC-1735 Slot does not work using another slot as a reference
It has been prioritized, so hopefully we will have a fix out soon.
Jason
@JasonBrynfordJones wrote:
Hi Guys
Jason
HI Jason
The bug is slot doesn't work if the start is a point, any point not just another slot. As a quick test try selecting the origin point.
Mark
Edit. Just tried again and I can start a slot from the origin but it does fail if you select an endpoint of a line or arc.
Mark Hughes
Ah yes, sorry about that.
I have updated the issue "Slot does not work when starting on a vertex"
Thanks again
Jason
Hi
I will ask around here if someone knows, but if this is a general Fusion issue, you would probably be better to post in the general Fusion forum
https://forums.autodesk.com/t5/design-validate-document/bd-p/124
This forum is related to workflows that are currently in Preview, and this post relates to a Fusion in the Browser bug.
All the best
Jason
@manuap44 wrote:
i'am getting this kind of warning when i constructing a plane(parallel).please help ,i don't know what to do.
Normally that happens if you have the construction folder hidden or the component you're working in is hidden, check all the lightbulbs are on. Can you get a screenshot of the browser as well?
Mark
Mark Hughes
