Tips and Tricks
Tips and Tricks
jon.hunwick
Alumni Alumni
Message 1 of 12
Tips and Tricks
jon.hunwick
I thought it might be useful to have a small Tips and Tricks section here. Do you have any tips to pass on to help everyone get the best out of PowerShape? If so, please share them here.
To whet your appetites, here's one:
 If you have a complex model, and need to select some faces that are hard to see (for example faces that are undercut in a die insert) you can use selection while inside 'Dynamic sectioning'.
Jon Hunwick
Replies (11)
Message 2 of 12
a1moldmaker
can this be pinned to the top of forum?
Bruce Green
Saying I cant always leads to failure
Saying I tried MIGHT lead to success
Message 3 of 12
ewshp
Thanks @jon.hunwick .
Didn't know that after years of using PowerSHAPE
Message 4 of 12
jon.hunwick
Hi Bruce.
Yes, I have made this into a 'Floating' topic now. It will always be at the top. Please feel free to add your own tips, everyone!
Jon Hunwick
Message 5 of 12
jon.hunwick
Here's another useful one:
If you press and hold the Tab key, you get a 2x zoom to your current cursor position. Handy when creating composite curve in tight regions. You change the zoom factor using Tools > Options.
If you haven't already discovered it, the Screencast tool (free from Autodesk) is a great way to share videos like this!
Jon Hunwick
Message 6 of 12
stdpattern
Screencast seems pretty slick.  I used it yesterday, and it integrates nicely with the forum.
Steve
Message 7 of 12
Hello everyone.
Here is a simple but very handy shortcut.
Press Alt + Left mouse button over the edge of a solid or surface or even above  lines and arcs. ( etc.etc)
It is automatically created a compcurve.
Thank you all
Giacomo
Message 8 of 12
Thanks jon it is really useful and awesome
Message 9 of 12
a1moldmaker
Move object between workplanes in macro
I am a bit embarrassed to admit i was not aware of this simple and easy functionality until very recently.
I am always working on macros to do repetitious steps because they are faster and more reliably correct, recently I needed to move some copied objects to a different location in the file for fixturing purposes and Jon H. was able to show me this.
as you can see it is very simple, hence my embarrassment at not knowing about it before
Bruce Green
Message 10 of 12
A very simple but very comfortable command that can be useful.
Selection filter:
TOTAL or PARTIAL selection with filter (like video screencast)
Use the selection filter by interacting directly in the project view, avoiding the filter window mask.
Thanks and good job
Giacomo
Il tuo contributo sarà utilizzato per migliorare la qualità della traduzione e può essere mostrato agli utenti in modo anonimo
Contribuisci
Chiudi
Message 11 of 12
Selection filter:
Thanks and good job
Giacomo
Message 12 of 12
I thought this was common knowledge, but I've seen a couple of guys who didn't know this so,,,, my favorite 4 shortcuts:
ctrl + J  = blank
ctrl + K  = blank except
ctrl + L  = unblank all
ctrl + Y  = toggle blanked objects
