the last operation caused an internal error in PowerShape standard on startup
csaragaglia
Message 1 of 9
csaragaglia
Every time I start PowerShape, I get that error.  I've logged in as admin, deleted ALL the _models, even deleted and recreated the MASTER MODEL.  Once I am in, I can open a new model without any error.  So my thought was to do that, delete the MASTER MODEL, and save the non error model as the MASTER.  Nope, same error message.  If I was able to keep the software open, it really wouldn't be an issue, but with a restricted number of licenses, I am repeatedly closing and reopening the software, only to see that message pop up 2 to 3 times while the software loads.  Any ideas forum?
Replies (8)
Message 2 of 9
csaragaglia
Sorry, running PowerShape 2019.1.1.19136, on a windows 64 bit system.
Message 3 of 9
suryakant.nirala
Autodesk Support
Autodesk Support
Hi @csaragaglia
Thank you for placing your query on Autodesk Community.
As I understand: When PowerShape is opened, the pop-up  displayes the warning message "The last operation caused an internal error in Autodesk PowerShape".
To remove the warning pop-up, do the following:
  1. Remove the parts and shareddb folders from the path: C:\Users\Public\Documents\Autodesk
  2. Unzip the attached Autodesk.rar folder.
  3. Copy parts and shareddb folders.
  4. Paste the folders at path: C:\Users\Public\Documents\Autodesk
  5. Launch PowerShape.
Please accept the solution button if my post fully solves your issue or reply with additional details if the problem persists.
Suryakant Nirala
Message 4 of 9
csaragaglia
 Suryakant, thank you, I'll try it.  Can you send a zip instead of a rar.  I can't open rar.
Message 5 of 9
suryakant.nirala
Autodesk Support
Autodesk Support
Hi @csaragaglia
Please click on the below link to download Autodesk.zip file.
https://a360.co/2xsTj0W
Suryakant Nirala
Message 6 of 9
csaragaglia
Thank you @suryakant.nirala
I've tried to follow your path, I have no "documents" folder in the
I have a public documents, but there is no autodesk folder in there.  See attached screen shot.  Running windows 7.
Message 7 of 9
csaragaglia
@suryakant.nirala, I do have a Delcam folder in the public documents folder with the parts, and shareddb folders.  Is that the one?
Message 8 of 9
suryakant.nirala
Autodesk Support
Autodesk Support
Hi @csaragaglia
In your attached snapshot,
1. Open C:\Users\Public\Public Documents\Autodesk
Note:- If you don't have Autodesk Folder in above location
2. Open C:\Users\Public\Public Documents\Delcam
Follow the steps to overcome the warning message.
Suryakant Nirala
Message 9 of 9
csaragaglia
@suryakant.nirala, THANK YOU!
Worked like a charm!
