microscribe digitizer not found
PLAS1991
PLAS1991
claire.louise.davies
The Microscribe can now be used by clicking the 'Devices' button off the top toolbar followed by 'Connect the probing or scanning device'.
It is best if you run the program as Administrator (right-click on the shortcut and select "Run as Administrator" from the menu) before clicking the button so that the drivers are correctly loaded. You can then click the 'Select driver' button to select the microscribe arm.
Claire-Louise Davies
Senior Manager, SQA
