getting the draft angle , min radius and max radius.
hx
hx
1.At PowerShape 2017
2.Import an model and select it.
3.Click the button to toggle the surfaces inspection mode.
4.move the curse to one surface and show the draft angle ,min radius, max radius.
Now Can I use command or some methode to return the draft angle ,min radius and max radius?
jon.hunwick
No, you cannot find these values directly.  What would you like to do with the values? Is this part of an automation project?
Jon Hunwick
