Whats the difference between a g2 curve and a bezier curve? when should i use one over the other?
thanks
Solved by ewshp. Go to Solution.
G2 curves are used for A-class surfaces (automotive / design) as they produce softer curves (less prone to have some "rough" edges on surfaces created using this kind of curve)
The letter G refers to "Geometric Continuity" and there are several levels, the main ones being :
0 : Linear continuity
1 : Tangeant continuity
2 : Curvature continuity
Bezier curves are G1.
are there draw backs to g2 curves? From your response, it sounds like i should use those all the time if surface quality is important to me. Thanks for your reply. I've got a few jobs better suited for powershape rather than solidworks but i dont have any training in it. i'm killing the hours on these jobs (not in a good way)
I would say the difference is on the aesthetic side of things and i have no typical use case where i need to use G2 curves. (meaning where i need to maintain continuity, tangeancy and constant curvature)
I stick to use bezier curves (G1) as on the products i am working on what i want first is continuity and tangeancy between differents elements or when creating some surfaces.
I will make some deeper experiments on G2 curves when i get some free time.
Hope this helps.
