Exchange 2023 compatibility issues
msjB59J5
msjB59J5
In Exchange 2023 version,  types and thickness are incompatible among styles. I have the following question.
1. When exporting from 2023 version to dwg, is there a way to make the line type and thickness compatible?
2. Is there a way to export to 2022 version?
wmtool
Hello
You can export using 2022 Exchange by clicking on your start menu. All versions of Exchange that are installed on your computer will be listed. Click on "Autodesk Manufacturing Data Exchange Utility 2022" then click on
"COM Register Autodesk Manufacturing Data Exchange Utility 2022" You will now be importing and exporting using exchange 2022. If you need to go back to 2023 you will need to COM register it.
msjB59J5
Thanks to you, this problem was solved simply and perfectly.
The Linetypes compatibility issue was resolved when setting it to 2021 instead of 2022 version.
