PowerShape Forum
Welcome to Autodesk’s PowerShape Forums. Share your knowledge, ask questions, and explore popular PowerShape topics.
Apply a macro to more than one ''object''
4 REPLIES 4
cagnoni.giacomo
628 Views, 4 Replies
Hello everyone.
I need your help to '' improve '' a macro.
The macro base is as follows and it works like this:
I manually selected a compcurve and the macro creates a circle in the center of it X Y, and Z minimum.
This macro works by selecting one compcurve.
STRING name = selection.name[0]
REAL X = compcurve[$name].cog.x
REAL Y = compcurve[$name].cog.y
REAL Z = selection.min_range.z
create arc FULL
r 3.5
$X $Y $Z
Now I would like to select more than one compcurve and apply the macro to each one of them
How can I do that?
Thank you
Giacomo
4 REPLIES 4
Try this:
LET $i = 1
LET $num = selection.number
LIST $select_names = SELECTION.NAMES
LET carry_on = ($i <= $num)
WHILE $carry_on {
	SELECT CLEARLIST
	STRING $name = $select_names[$i]
	add CompCurve $name
	REAL $X = compcurve[$name].cog.x
	REAL $Y = compcurve[$name].cog.y
	REAL $Z = selection.min_range.z
	create arc FULL
	r 3.5
	$X $Y $Z
LET $i = $i + 1
Rafael Sansão
Thank you
Is perfect working properly.
A curiosity.
I have tried this way but it doesn't work
LET numturn = selection.number
WHILE $numturn {
LET numturn = $numturn - 1
STRING name = selection.name[$numturn]
create arc FULL
r 3.5
$X $Y $Z
What's wrong in my macro?
Thank you
When you create the first circle, the selection of composite curves is lost. This generates the error in your macro.
Try "RESTORE_SELECTION"
WHILE $numturn {
create arc FULL
r 3.5
$X $Y $Z
RESTORE_SELECTION
RESTORE_SELECTION
Rafael Sansão
Very well!
Now the macro works correctly!
Thank you
