4k Resolution Issues
Message 1 of 8
Hi
I am having some issues with the levels toolbar displaying really small on a 4k monitor. I have the text scaling set to 200% and its still hard to see? I can only see half the powershape"taskbar" as well. This is also the case with the material selection form.
I have read posts on here where people are having similar problems with 4k resolution but the posts are 5 months old? Has this issue been fixed and if so how do rectify the problems?
Replies (7)
Message 2 of 8
jonathan.artiss
Hi @Anonymous
Thank you for posting on the Autodesk PowerShape Forum!
@Anonymous wrote:
Hi
I know that Autodesk is continually working at supporting 4K resolution and as you can see there are still some scaling problems.
I would like to suggest that you reduce the resolution down to something like 1920 x 1080, then test what scaling will work best to enlarge the icons and fit the taskbar into full view. This will likely solve the graphics issues you are currently seeing.
Cheers,
Jonathan Artiss
Application Engineer
Submitting & Viewing Support Requests | Web Support | Phone Support
Message 3 of 8
info
Yes I confirm. On 4k monitor at resolution of 3840x2160 PowerShape has problem on DPI scaling mostly on toolbar level.
Hope they will fix it on next update.
Message 4 of 8
bgreen_a1moldmaker
Has Autodesk resolved any of the issues with 4k monitors yet?
Message 5 of 8
This is well detailed.
Message 6 of 8
bgreen_a1moldmaker
how do you mean well detailed...what is the fix
Message 7 of 8
simon
Well detailed.. as in well complained about.
No fix though.
Message 8 of 8
You all ganging up on me.
