What is the macro command corresponding to the “Copy” command?
411321393
411321393
What is the macro command corresponding to the “Copy” command?G_0RJ338X%DOOB%DQWC`E8A.png
Sean571
There is not a command for that as far as I know, if it doesn't show up in echo commands then usually you are out of luck. There are some functions to get the number of segments and you might be able to use a widget to try and get all the info, but there isn't an easy "copy" macro command
Sean Wroblewski
Applications Engineer
