PowerShape and PowerMill API Forum
Welcome to Autodesk’s PowerShape and PowerMill API Forums. Share your knowledge, ask questions, and explore popular API topics.
VB - Get the selected z-depth
5 REPLIES 5
manuel.matheis
395 Views, 5 Replies
I want to get the z-depth.
The function of the button in my plugin should be the same as the button in the toolpath. (see Attachment)
I can use this command
pm.Execute("MODE OBTAIN ZHEIGHT """)
then I can select the z-depth in Powermill
and than i don´t know, how i get the value into a textbox.
Can someone help me?
thanks in advance
5 REPLIES 5
icse
in reply to: manuel.matheis
this sets the min value textbox:
pm.Execute("MODE OBTAIN ZHEIGHT 'ZRange.Minimum.Value'")
luc_ponsaerts
in reply to: icse
I used the mode command to hide input windows as in MODE NOGUI ....
MODE OBTAIN ... is new for me.
There are more MODE commands, where can I find the necessary documentation/information?
Didn't find anything in Help/parameters/reference, mor in the PM Macro manual.
manuel.matheis
in reply to: icse
yes, but I want to geht the parameter $ZRange.Minimum.Value in my application.
How I get the parameter after I pick the depth?
icse
this function should return the value of this textblock as a string:
pm.ExecuteEx("PRINT PAR $ZRange.Minimum.Value").ToString();
manuel.matheis
in reply to: icse
Thank you, but my problem is different.
after the command---powermill.Execute("MODE OBTAIN ZHEIGHT 'ZRange.Minimum.Value'")---
I have to select the depth in Powermill, so my application has to wait until I have selected the model.
I have currently solved this with a loop, but I think there is a better solution!
Here is my code:
        Dim depth As String
        Dim depth_old As String
        depth = powermill.ExecuteEx("PRINT PAR $ZRange.Minimum.Value").ToString
        depth_old = depth
        powermill.ExecuteEx("MODE OBTAIN ZHEIGHT 'ZRange.Minimum.Value'")
        'powermil. ?????waiting for selection?????
        While depth = depth_old
        End While
