Variable Minimum Radius Shading
david_moir
Message 1 of 1
david_moir
Hi all.
Around 10 years back I worked at a company that used Powershape + Powermill.  In Both PS + PM we had a Macro or VB that activated when you selected Minimum Radius Shading.  This brought up a slider bar that allowed you to dynamically change the minimum radius to make it larger or smaller, next to the slider was an input box that showed the value as the slider moved or allowed you to input a value manually.
Has anyone heard of this or know where I might be able to get this function?  Any insight into how i might write this myself?
I'm also interested in any Macros or VB for PS that would look at a model and highlight areas that would require EDM.  The minimum radius tool I mention above would be a step towards this but wouldn't highlight everything.
Replies (0)
