Surface Extension with loop
hugo_wy
Message 1 of 8
hugo_wy
Hi.
I am trying to create multiple Surface Extensions using a Loop, after selecting multiple composite curves.
I am using Vbscript - HTM.
The code works fine if i only select one composite curve.
If i select more than one composite curve, it doesn´t work.
Here is the code:
<HTML>
<HEAD>
<script language="VBscript">
// Connect to PowerSHAPE
set PowerSHAPE = Window.external
// the routine called when the button is clicked..
Sub Apply_click()
//get the number of items in the current selection
num_items = PowerSHAPE.Evaluate( "SELECTION.NUMBER" )
IF (num_items = 0) then
MsgBox ("Nothing is selected")
Else
Dim i
i = 0
// loop through all the selection
For i = 0 to num_items - 1
// get the name
cName = PowerSHAPE.Evaluate("SELECTION.OBJECT[" & i & "].NAME")
PowerSHAPE.Exec("ADD COMPCURVE '" & cName & "'")
PowerSHAPE.Exec("CREATE SURFACE EXTENSION")
PowerSHAPE.Exec("ALONG SURFACE_INTERNALS")
PowerSHAPE.Exec("DISTANCE 4")
PowerSHAPE.Exec("APPLY")
PowerSHAPE.Exec("CANCEL")
Next
End Sub
</script>
</HEAD>
<BODY>
<H3>Extend surfaces</H3>
<FORM NAME=test>
<INPUT TYPE=button VALUE=" Apply " onClick=Apply_click() ><p>
</FORM>
</BODY>
</HTML>
Replies (7)
Message 2 of 8
l.ponsaerts
You have to unselect the composite curves first .
<!-- // Connect to PowerSHAPE
                Sub Apply_click()
                                Else
                                                Dim i
                                                i = 0
        // get the name
        Powershape.Exec("select clearlist")
                                                Next
End Sub
--> </script>
</HEAD>
<BODY>
                <FORM NAME=test>
                </FORM>
</BODY>
</HTML
Message 3 of 8
hugo_wy
Thanks for respond quickly.
Still doesn´t work.
See the attach video.
The code creates 2 surfaces with the same composite curve.
I am working with Delcam PowerSHAPE 2015 (SP4 CR 15.1.46)
Can you tell me how i can save my selection in a List or an Array?
Message 4 of 8
l.ponsaerts
I apologize. My mistake, I didn't think. I was indeed thinking working on a list.
I don't have PS2015, we work with PS 2023.
Remove the select clearlist, it is useless.
To get a list of the names of the comp curves, try :
LIST compcurves = { }
LET i = 0
LET carry_on = ($i < $num_items)
WHILE $carry_on {
   LET comp_name = SELECTION.OBJECT[$i].name
   LIST_ADD $compcurves END $comp_name
   LET i = $i + 1
I didn't have the time to check it out, but hope it works.
Message 5 of 8
hugo_wy
Hi.
I used your code and implemented in my MACRO.
The composite curves are in the LIST, but i am having trouble in accessing each item of the LIST.
The command "ADD COMPCURVE $compcurves($i_2)" isn´t working. I don´t know why.
I tried many ways, without success, to PRINT the first item of the LIST:
print $compcurves (0)
print $compcurves [0]
print $compcurves {0}
print $compcurves {[0]}
I convert the code to a MACRO:
LET num_items = SELECTION.NUMBER
IF ($num_items == 0) {
PRINT ERROR 'Nothing is selected'
RETURN
} Else {
//Cria uma LIST vazia e adiciona a seleção á lista
LET i = 0
WHILE $carry_on {
LET i = $i + 1
LET i_2 = 0
LET cond = ($i_2 < $num_items)
WHILE $cond {
select clearlist
DISTANCE 4
APPLY
CANCEL
LET i_2 = $i_2 + 1
Message 6 of 8
l.ponsaerts
There are some oddities in Powershape macro language ...
Hence, in automation projects I always try to use the API, instead of the raw macro commands.
First , one has to use [] instead of () when accessing the items in a list.
Second, when accessing a list, the list is 1 based instead of 0 based, so , the first item in the list has to be accessed as $compcurves[1] instead of $compcurves[0]
Third, and this is the strangest thing : although , in the macro , we use : STRING comp_name = SELECTION.OBJECT[$i].name , the variable $comp_name is not a string but an integer, as the name of the composite curve seems to be an integer. So, the command ADD COMPCURVE $compcurves[$i] generates an error.
A possible solution is to use a temporary string variable :
STRING temp = $compcurves[i]
ADD COMPCURVE $temp
That seems to work.
Here is the modified macro (tested on a surface in PM2023)
LIST compcurves = {}
STRING comp_name = ''
STRING temp = ''
RETURN
} Else {
LET i = 0
WHILE $carry_on {
$comp_name = SELECTION.OBJECT[$i].name
LET i = $i + 1
LET i_2 = 1
LET cond = ($i_2 <= $num_items)
WHILE $cond {
select clearlist
$temp = $compcurves[$i_2]
ADD COMPCURVE $temp
DISTANCE 4
APPLY
CANCEL
LET i_2 = $i_2 + 1
QUIT
Message 7 of 8
l.ponsaerts
before and after ...
Message 8 of 8
hugo_wy
Thanks.
It works perfectly.
With this new information about Lists i can do a lot of automation macros.
