Powermill process still running in the background after closing
huyc2GQZL
huyc2GQZL
After closing Powermill, I can see in the system resource manager that a process called Powermill.exe is still running and occupying memory (see image below).
The plugin I developed needs to release some resources after Powermill is closed, but I can’t capture the closing event.
Can anyone help me?
Thank you.
luke.edwards.autodesk
Hi, if you are using the PluginFramework and inheriting/implementing "PluginFrameworkWithPanes, IProductInterface" then you can implement the shutdown_framework operation and use this to clear up your resources.
Hope this helps...
Luke Edwards
Consulting Services Manager
huyc2GQZL
Thankfully, I inherited the "shutdown_framework" function to solve this problem
Thanks again
