PowerShape and PowerMill API Forum
Welcome to Autodesk’s PowerShape and PowerMill API Forums. Share your knowledge, ask questions, and explore popular API topics.
PowerMill Plug-In mouse wheel scroll issue.
1 REPLY 1
ikims1126
295 Views, 1 Reply
Hello. Everyone.
I'm making a PowerMill plug-in program.
In the plug-in, there is a tree-view which lists up entities in PowerMill.
If entities are enough to exceed the tree-view layout, the scroll bar pops up.
But, No matter how much I move the mouse wheel, the scroll bar in the tree-view does not move.
So I try to catch the movement of the wheel like below, but it doesn't work also.
the .XAML head code
<UserControl x:Class="PanelName"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
mc:Ignorable="d"
MouseWheel="Window_MouseWheel"
xmlns:local="clr-namespace:TRANSFORM_Code">
the .CS code
private void Window_MouseWheel(object sender, MouseWheelEventArgs e)
MessageBox.Show("Catch wheel");
This codes work to catch the mouse wheel movement, and show message box.
In normal case, whenever I move the mouse wheel, the message box pops up.
But it didn't.
I guess it's because of the PowerMill plug-in framework.
How can I solve this problem?
I will wait you comment.
Thanks to read this.
1 REPLY 1
Sean571
in reply to: ikims1126
Scrolling in a plugin used to work in pmill 2016 but I think somewhere between 2017-2019 PowerMill started preventing an embedded plugin from scrolling. My guess it they didn't mean to do this, but ever since I have not found a workaround.
Sean Wroblewski
Applications Engineer
