Powermill Automation API
lopezerik73
Message 1 of 9
lopezerik73
Hello.
I´m newbie with Powermill API and i want to ask some help.
I have a little C# form menu with two buttons (For the moment) the first button works fine, but the second not work and get me an error.
Some body can help me please?
I attacht 2 images about the error i say.
Many thanks in advance.
kindly regards.
   Erik
//POWERMILL AUTOMATION
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using Delcam.ProductInterface.PowerMILL;
using Delcam.ProductInterface;
using Delcam.Geometry;
namespace CS_FORM_TEST1
public partial class Form1 : Form
public Form1()
InitializeComponent();
private void Form1_Load(object sender, EventArgs e)
private void button1_Click(object sender, EventArgs e)
PMAutomation powerMILL = new PMAutomation(Delcam.ProductInterface.InstanceReuse.UseExistingInstance);
PMProject pSession = powerMILL.ActiveProject;
private void button2_Click(object sender, EventArgs e)
Delcam.FileSystem.File importFile = new Delcam.FileSystem.File(@"C:\Users\*****\Desktop\HOLES.dgk");
PMModel myModel = pSession.Models.CreateModel(importFile);
Replies (8)
Message 2 of 9
move this line just below your class declaration:
and add another definition of the active session at the beginning of the button2_click event:
your problem is that the code inside of button2_click doesn't know what "pSession" is because it is being defined only in the other button's method.
This should work:
            public Form1()
Message 3 of 9
lopezerik73
Hello.
First  at all many thanks for your answer and help me nbaranowski.
Your solution is not correct at all.
Now when execute the code start automatically the Powermiil and not when press the button for start it.
But the second button works nice and import the file correctly.
Many thanks again.
Kindly regards.
  Erik
Message 4 of 9
You have the object set to "UseExistingInstance" so i assumed your session was already open.
You can just move another copy of the PMAutomation object into the button2_click to get what you want.
This is tested and works:
using System;
using System.Data;
using System.Linq;
using System.Text;
        public Form1()
            PMAutomation powerMILL = new PMAutomation(Delcam.ProductInterface.InstanceReuse.CreateNewInstance);
            Delcam.FileSystem.File importFile = new Delcam.FileSystem.File(@"C:\Users\*******\Desktop\HOLES.dgk");
Message 5 of 9
lopezerik73
Many thanks nbaranowski.Smiley Wink
Now works perfect as i want.
I try now to add more options to my little API.
Thanks again.
Kindly regards.
   Erik
Message 6 of 9
Khoa_NguyenDang
I have the same Problem but can not fix with your method
Please help me
Message 7 of 9
luke.edwards.autodesk
Hi, what version of PowerMill are you running?  Can you open task manager and see if pmill.exe is running when you get this error?
Luke Edwards
Consulting Services Manager
Message 8 of 9
Khoa_NguyenDang
Hi @luke.edwards.autodesk
i am using Power 2022 and PowerMill API 1.1.53
I aldready open PowerMill when run Form
Message 9 of 9
Hi, does it give a stack trace in the error report?  That would help me work out which line it is failing on.
One thing to check, is it PowerMill you are running or PowerMill Viewer?
Luke Edwards
