PowerShape and PowerMill API Forum
Welcome to Autodesk’s PowerShape and PowerMill API Forums. Share your knowledge, ask questions, and explore popular API topics.
Need a new plugin guide
6 REPLIES 6
peterquRXR7S
464 Views, 6 Replies
I am trying hard on making a plugin. But the plugin guide is too old. I downloaded VS 2023. The framework is 7.0. Where can I find the latest version?
6 REPLIES 6
barr.jarryd
in reply to: peterquRXR7S
There is no latest version. You have to create the plugin, generate the DLL, manually change the framework in the proj folder.
I could be a bit outdated here, but that is what I have been doing.
There is an example of all this pulled together here if it helps you get started quicker:
https://github.com/lukeedw/powermill-api-examples/tree/master/addin-example-powermill-plugin
As barr.jarryd says, you will need to change the framework version as required.
Luke Edwards
Consulting Services Manager
Thank you! Luke, I followed the instruction and Got a few errors.
I can't find Delcam.Plugins.Framework.
peterquRXR7S
I found the Delcam.Plugins.Framework.dll. The the program still doesn't work.
cryamerica26
in reply to: barr.jarryd
To get started creating a new plugin, follow the steps below.
  1. Navigate to the WordPress installation’s wp-content directory.
  2. Open the plugins directory.
  3. Create a new directory and name it after the plugin (e.g. plugin-name).
  4. Open the new plugin’s directory.
  5. Create a new PHP file (it’s also good to name this file after your plugin, e.g. plugin-name.php).
Regards
Bobby Jack
<a href=https://https://www.cryamerica.org/>cryamerica </a>
peterquRXR7S
in reply to: cryamerica26
Thank you for your reply. I guess this is a different kind of plugin.
Technology Administrators
