PowerShape and PowerMill API Forum
Welcome to Autodesk’s PowerShape and PowerMill API Forums. Share your knowledge, ask questions, and explore popular API topics.
How to add a judgment in scrpt of Autodesk manufacturing post processor ,Determine whether PowerInpsct is running 。
1 REPLY 1
yongjunhan
230 Views, 1 Reply
Dear All :
CS.cut is a inspect program , it was creat in PowerMill not PowerInpsect , Use S.pmoptz to debug CS.cut , it was ok 。
How to add a judgment in scrpt of S.pmoptz ,Determine whether PowerInpsct is running 。 If Powerinspect is open, the output is normal. If PoewrInspect is not open, an error message is displayed to open PowerInpect .
Please help me to write such a judgment, thanks!
Thanks and Best Regards
HanYongjun
1 REPLY 1
l.ponsaerts
in reply to: yongjunhan
after doing some searches on internet : it seems to be impossible to do this with javascript, as javascript does not have access to system level processes.
But with VBScript it would be possible. Couldn't test it though.
I found this example :
vbscript
' Function to check if a process is running
Function IsProcessRunning(processName)
    Dim objWMIService, colProcesses, objProcess
    ' Get the WMI service object
    Set objWMIService = GetObject("winmgmts:\\.\root\cimv2")
    ' Query for processes with the specified name
    Set colProcesses = objWMIService.ExecQuery("SELECT * FROM Win32_Process WHERE Name = '" & processName & "'")
    ' Check if the process is running
    For Each objProcess In colProcesses
        IsProcessRunning = True
        Exit Function
    Next
    ' Process not found
    IsProcessRunning = False
End Function
' Example usage
Dim processName, result
processName = "notepad.exe" ' Replace with the name of the process you want to check
result = IsProcessRunning(processName)
If result Then
    WScript.Echo processName & " is running."
Else
    WScript.Echo processName & " is not running."
I don't know if this will work with the post. Have fun !
