Getting the name of different models tree name.
hx
Message 1 of 13
hx
how can I use the PowerShape API to get the different model's tree names.
as two image below.
Replies (12)
Message 2 of 13
hx
Upload the examples.
Message 3 of 13
luke.edwards.autodesk
Hi, at the moment the API does not support features and components.  Is that what you are referring to?
Luke Edwards
Consulting Services Manager
Message 4 of 13
Do you just need to know how to use a model other than the active one? This snippet will let you toggle between opened models:
PSAutomation powerSHAPE = new PSAutomation(Autodesk.ProductInterface.InstanceReuse.UseExistingInstance);
        PSModel model = powerSHAPE.Models["ModelNameHere"];
Message 5 of 13
Note that you can only work with the ActiveModel.  I am not sure that the code above will actually switch the windows such that the other model becomes active.  You would need to do something like:
model.Window.MakeActive();
Luke Edwards
Message 6 of 13
hx
Hi @luke.edwards.autodesk.
I just thick I need Another way to achieve it.
1.Click the menu 'Edit'->'Select'-> Select all. to select all the features or compoents.
2.right click the toolBar and select the 'Selection information' button.
4. Can I Use macro commands or some methodes to print these information?
Message 7 of 13
You can interrogate a solid to find out how many features there are with the command:
print solid['1'].features
(where '1' is the name of the solid).
You can then interrogate the name of each feature
print solid['1'].feature[1].name
print solid['1'].feature[2].name
The features are indexed from 1 above.
Does this help?
Luke Edwards
Message 8 of 13
hx
The prerequisite for using these commands is had know the name in the tree list first. Whether the entity is solids or assemblies.
But now Make me confused is getting the names in tree window.
Kind Regards,
Hins Ho.
Message 9 of 13
hx
If the tree list components are solid, I can use the code to get names and they attributes.
But the assembly can not.
Code below:
Dim sb As New System.Text.StringBuilder
For i As Integer = 0 To PSInstance.ActiveModel.Solids.Count - 1
   sb.AppendLine(PSInstance.ActiveModel.Solids.Item(i).Name)
Next
Hins Ho
Message 10 of 13
Yes, unfortunately we don't yet support Assemblies in the API.  You would be able to get them with the commands such as the following.  The first gets the number of components and the rest get the names.
print MODEL.COMPONENTS
print COMPONENT[1].NAME
print COMPONENT[2].NAME
print COMPONENT[n].NAME
Luke Edwards
Message 11 of 13
hx
The command can use return number of compoents.
 but the print the compoent's name will return no such compoent.
Message 12 of 13
hx
hi @luke.edwards.autodesk
Can you have any other method to get the component's name?
Best regards.
Hins HO.
Message 13 of 13
pedro_babo
how can I get the number of enteties selected? and theyr names
string NumeroComponentes = PowerSHAPE.Execute("print selection.number");
this guives one error hou can I get Powershape response to a string?
