create an aligned workplane to a fitted arc
luc_ponsaerts
luc_ponsaerts
The created workplane is not aligned to the fitted arc. (see attachment)
foreach (PSMesh m in meshes)
   string mName = m.Name;
   // create arcs around each model(at largest diameter)
    PSArc psArc = psModel.Arcs.SketchArcThroughThreePoints();
   // align workplane in center of each arc
   PSWorkplane psWorkplane = psModel.Workplanes.CreateWorkplaneAlignedToEntity(psArc, psArc.Centre);
   psWorkplane.Name = mName;
   psModel.ActiveWorkplane = null;
The workplanes are created in the arc center, but are not aligned to the arc.
What am I missing here ?
luc_ponsaerts
Found the solution. I was mistaken by the name of the command : .CreateWorkplaneAlignedToEntity thinking that the workplane created would be aligned to the entity (first parameter of the command).
The solution is to use :the command CreateWorkplaneFromZAxis :
Vector vector = new Vector();
vector = psArc.CentreNormal;
PSWorkplane psWorkplane = psModel.Workplanes.CreateWorkplaneFromZAxis(psArc.Centre, vector);
Works fine.
