PowerShape and PowerMill API Forum
Welcome to Autodesk’s PowerShape and PowerMill API Forums. Share your knowledge, ask questions, and explore popular API topics.
Close the modal dialog.
5 REPLIES 5
hx
621 Views, 5 Replies
As the image show.
If the PMinstance is in modal dialog. the api will get issues by DoCommand.
How can I close it by the api?
5 REPLIES 5
icse
in reply to: hx
Edit:
It seems like if the open dialog is opend you can close it with this line:
//opens the dialog
PROJECT RECOVERY OPEN PROJSELECTOR
print 'test'
//closes the dialog
nicholas_wu
in reply to: hx
PROJECT RECOVERY OPEN PROJSELECTOR "(project_path)"
hx
in reply to: nicholas_wu
I know this command, but what I want is, if PowerMILL is in the mode dialog box open state, is there a way to close the dialog box through the command or API?
ondrej.mikulec
in reply to: hx
I don’t think that there is any command that closes the modal dialog. I am assuming that when Powermill raises the modal dialog, the software main loop is stopped, and the only way to continue is to interact with the modal dialog.
You can manage to avoid raising the modal dialog by having the “DIALOGS MESSAGE OFF” and “DIALOGS ERROR OFF” during any interactions with Powermill. And anywhere a modal dialog raising is expected, then there are extra commands available such as “YES” at the end of the command or the examples showed in the replies above.
For example, the “YES” suffix can be in the “EXPORT MODEL "model" FILESAVE "C:\targetPath.dgk" YES" which always overwrites the file that already exists.
luc_ponsaerts
in reply to: hx
What about the NOQUIBBLE parameter ?
ex.g.
DELETE STOCKMODEL ; NOQUIBBLE
NOQUIBBLE = No Question With this option when you delete an entity no question is displayed to confirm the suppression of the entity.
