Windows 11 23h2 breaks Autodesk Products
bcarson69JE6
Observer Observer
bcarson69JE6
Observer
Observer
Basically all Autodesk Software that uses  the new launcher, Autodesk Access (Any software usually from 2021 and newer uses it) will not work or download if your computer is updated to Windows 11, Version 23H2. If you had all this software downloaded before the update, then it will give you a license error. If you try downloading after the update, it will error out and it won't let you download.
Anyone else have this issue or is it just me and my company?
iamcdn79
I've had Windows 11 23h2 installed since Nov. 2023 and haven't had any issues with Autodesk software
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
JStevens2
Observer
Observer
Question for you. Did you install your Autodesk products after the upgrade or were they already installed?
iamcdn79
Windows was already pre-installed
Windows 11 Pro
