Which extension is best for import model & Triangle file into Powermill 2018?
Hi friends,
can anyone suggest me Which extension is best for import model & Triangle file into Powermill 2018?
General i use .DGk extension for import Models file.
if i import other Extension  like  .prt,.Stp,IGES,.x_t, or any then any pro cons?
regards,
Krupal Vala
Powermill imports a lot range of file extensions.
You easily can open them in File > import
You can also use Powersahpe to edit files and export in another extensions.
@Anonymous
i know that. but i want to know which extension is best for import model.
if you import .prt its take time  to load & too many surface error found.
regards,
Krupal vala
It's only my thought, but as for me very good extension is .dmt - it uses for visualization in Powermil and imports faster then other.
