Vortex roughing path
ismV3CFD
ismV3CFD
Hi
 We are facing the problem on Vortex machining here I used 12.0 mm bullnose with radius of 0.8 I want to cut full depth of  21.59 mm the toolpath  results shown in attached file  first depth started outside area to inside  its fine , after that its going to next level depth its going to ramp but I don't know why its going ramp that is also possible outside cutting .when going to ramp tool wear is more compare to side milling . kindly give me the solution for the same .
version : -Autodesk PowerMill Ultimate 2019Version: 2019.0.3.2019022Build Date: Mon Jun 18 10:52:51 UTC 2018Status: Full Release
os -
Windows 10
emilie.a
Could you please contact your local support team so that they open a ticket with our development team? It would help us investigate the problem.
Emilie
Emilie.A
Software Development Manager
ismV3CFD
Hi
   Thanks for your reply, already i have asked our local supplier their also given the same reply to us anyway kindly give the solution to us as soon as possible .
dkakuma
Hi ,
try to split the toolpath to levels
