PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Variables used in the Setup Stock form
1 REPLY 1
john_lute
436 Views, 1 Reply
I have been reviewing the Powermill Reference Parameter page in search of variables so that I can retrieve and modify values set in the setup stock in my macros. For testing I have activated Echo Commands. When I type "print $Block.Limits.XMax"  in the command window, I receive the X max value in the form. I know this is not setup stock, but it is a test to validate correct syntax. When I type "print $setup.Stock.Limits.XMax" I receive and error "#ERROR: Invalid name". My goal is to read the values from the setup stock and include in my setup sheet.
Regards.
Labels (4)
1 REPLY 1
cfastNJWK6
in reply to: john_lute
You need to declare which setup you want to show the information for by the setup Name
print $entity('setup', 'SetupNameHere').Stock.Limits.XMax
Technology Administrators
