v18 is very slow in simulation
cheidenfelder
Message 1 of 11
cheidenfelder
I just tested v16 to v18. simulation is 60 times slower. anybody else having problem?
Replies (10)
Message 2 of 11
Alfred.NESWADBA
welcome @Anonymous!
May I ask which product are you referring to?
This here is the AutoCAD forum but within that product a "simulation" is not a function OOTB.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 11
john.vellek
HI @cheidenfelder,
Can you describe your computer, OS and the specific application and version to which you are referring? There is no built-in simulation in core AutoCAD so I need a bit more detail please.
John Vellek
Message 4 of 11
cheidenfelder
This is in powermill. I realized I posted this in AutoCAD forum, so I posted my question under Powermill
Message 5 of 11
cheidenfelder
Message 6 of 11
jitendra.chaudhari
Hi @cheidenfelder,
Thank you for contacting Autodesk Community Forum.
Please disable PowerMill Robot plugin from -
File-->Options-->Manage Installed Plug ins
Can you please confirm the exact version of the PowerMill 2018 that currently you are using at your end? IS this project specific instance? Can you please record a small video and supply us a sample PM project so that we test it our end?
Please verify and confirm.
Jitendra Chaudhari.
Message 7 of 11
cheidenfelder
HERE IS A VIDEO.. ITS ALL FILES.. VERSION 201
8.0.4.1212130
Message 8 of 11
jonathan.artiss
Hi @cheidenfelder
8.0.4.1212130
I have just installed and done some testing in the latest version, 2018.1.0.1212141. There seems to be a speed up, you will need to as @jitendra.chaudhari mentioned disable the Robot Plug-in. But you should see a significant speed increase.
Jonathan Artiss
Application Engineer
Submitting & Viewing Support Requests | Web Support | Phone Support
Message 9 of 11
cheidenfelder
This video is with robot disabled. Is the new version available?
Message 10 of 11
jonathan.artiss
It was just released today, you should be able to see it in your Autodesk Desktop App or in your Autodesk Account.
Jonathan Artiss
Message 11 of 11
cheidenfelder
I just down loaded and tested the new version. This makes a huge improvement, thanks.
