Using Powermill with a Thermwood C67 5 axis router?
liam.carr59V7G
liam.carr59V7G
Does anyone have any experience using powermill with Thermwood 5 axis CNC routers?
Do Autodesk have post processors available for this type of machine?
Therwood will only provide/support posts for Mastercam and no other CAM package.
TK.421
i have a dms 5 axis router; i can send you the post to use as a guide to build your own?  are you on maintenance or subscription with autodesk? they should provide you one or build one for you
the numbers never lie
Jonathan.Artiss-DSI
@liam.carr59V7G
I worked with a customer about 3 years ago that had a Thermwood 67D. We had it up and running on PowerMill without any issues.
Jonathan Artiss
Senior Applications Engineer | DSI
Autodesk Expert Elite member
DSI, Design and Software International Autodesk Gold Partner
liam.carr59V7G
Ah, That's good to know, I'm currently using powermill with my 7 axis Kuka Robot arm, and really want to use it with the 5 axis router as well.
The router will be 2nd hand so will come with a post processor and kinematic model although they will be for Mastercam. Is it best to send these to Autodesk when requesting a powermill compatible post and simulation model?
liam
