PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
UserDefined ToolPath with macro
10 REPLIES 10
Message 1 of 11
jsweatherbie
705 Views, 10 Replies
Today im trying to make a User Definedmacro for helicals and it doesnt seem to imput the Thru ,To Depth and full dia
heres the code
bool runAgain = false
do {
//SHOWS YOU A LIST OF TOOLS
string list options={"3-inch","2-inch","25mm","20mm","1/2","12mm","6mm"}
int i = INPUT CHOICE $options "Choose a tool"
string tpName = $options[$i]
FORM FEATURESELECT
MACRO PAUSE "SELECT A HOLE TO HELICAL" + crlf + "AND CLICK RESUME"
switch $i {
case 0
IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "C:\Users\User\AppData\Local\Autodesk\PowerMill\My-Strategies\HELICAL\3-INCH.ptf "
break
case 1
IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "C:\Users\User\AppData\Local\Autodesk\PowerMill\My-Strategies\HELICAL\2-INCH.ptf "
break
case 2
IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "C:\Users\User\AppData\Local\Autodesk\PowerMill\My-Strategies\HELICAL\25MM.ptf"
break
case 3
IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "C:\Users\User\AppData\Local\Autodesk\PowerMill\My-Strategies\HELICAL\20MM.ptf "
break
case 4
IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "C:\Users\User\AppData\Local\Autodesk\PowerMill\My-Strategies\HELICAL\500.ptf"
break
case 5
IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "C:\Users\User\AppData\Local\Autodesk\PowerMill\My-Strategies\HELICAL\12MM.ptf"
break
case 5
IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "C:\Users\User\AppData\Local\Autodesk\PowerMill\My-Strategies\HELICAL\6MM.ptf"
break
//Choosing the Operation for the Helical
string list Operation ={"To Depth","Full Dia","Thru hole"}
int o = INPUT CHOICE $Operation "Choose a Operation"
switch $o {
case 0
EDIT DRILL DEPTH EXACT
case 1
EDIT DRILL DEPTH HOLE
case 2
EDIT DRILL DEPTH THRU
RENAME TOOLPATH "1" $tpName
EDIT TOOLPATH $tpName CALCULATE
FORM ACCEPT SFDrilling
FEATURESELECT CANCEL
//RUNS AGAIN IF ANSWER IS YES
$runAgain = QUERY "Helical Another Hole?"
} while $runAgain == true
Tags (1)
Labels (1)
10 REPLIES 10
Message 2 of 11
Try this:
do {
FORM FEATURESELECT
switch $i {
case 0
break
case 1
break
case 2
break
case 3
break
case 4
break
case 5
break
case 5
break
switch $o {
case 0
EDIT PAR "Drill.DepthType" "full_diameter"
case 1
EDIT PAR "Drill.DepthType" "hole"
case 2
EDIT PAR "Drill.DepthType" "thru"
Rafael Sansão
Message 3 of 11
so after it imports the template and you select the "Operation" with the drop down it doesnt stay for some odd reason... it works just not the operation. do i need to define it before hand to tell it when it imports ?
Message 4 of 11
Did you try the code I sent?
It should do exactly what you're looking for.
I changed this part of the macro:
switch $o {
case 0
case 1
case 2
Rafael Sansão
Message 5 of 11
jsweatherbie
in reply to: jsweatherbie
yes i did and it never set the operation for DepthTypes.....  do you need to pin point the toolpath?
in the reference it states "{toolpath}.Drill.DepthType "
OR do i need to move the:
Message 6 of 11
Try now.
There was an error on the Switch.
I fixed an issue on the Switch and I made some improvements.
$entity("Toolpath","").Drill.DepthType = "hole"
Change the parameter directly on the toolpath
do {
FORM FEATURESELECT
switch $i {
case 0
	IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "C:\Users\User\AppData\Local\Autodesk\PowerMill\My-Strategies\HELICAL\3-INCH.ptf"
	BREAK
case 1
	IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "C:\Users\User\AppData\Local\Autodesk\PowerMill\My-Strategies\HELICAL\2-INCH.ptf"
	BREAK
case 2
	BREAK
case 3
	IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "C:\Users\User\AppData\Local\Autodesk\PowerMill\My-Strategies\HELICAL\20MM.ptf"
	BREAK
case 4
	BREAK
case 5
	BREAK
case 5
	BREAK
switch $o {
case 0
	$entity("Toolpath","").Drill.DepthType = "full_diameter"
	BREAK
case 1
	BREAK
case 2
	$entity("Toolpath","").Drill.DepthType = "thru"
	BREAK
IF entity_exists("Toolpath",$tpName) {
	$tpName = new_entity_name("Toolpath",$tpName)
RENAME TOOLPATH ; $tpName
Rafael Sansão
Message 7 of 11
jsweatherbie
it only works if you have a tool path already open it doesnt actually modify the one that was created im thinking i just have to have it active its self and open the menu to have it changed
Message 8 of 11
Did you copy and try to run my last macro?
I tested it from my side and it does exactly what you want.
Rafael Sansão
Message 9 of 11
jsweatherbie
im running 2020 powermill
Message 10 of 11
This should work in 2020.
Can you download the file "test.txt" and change the extension to "test.mac" and try to run?
If it still doesn't work, record a video showing the problem
Rafael Sansão
Message 11 of 11
It worked out great it was me who labeled things wrong lol thank you for your help I learned alot
Technology Administrators
