PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Types of UI in macros
4 REPLIES 4
jsweatherbie
438 Views, 4 Replies
Hello . I’m trying to make a simple marco but all I know is the yes/no prompt and the drop down menu prompt  . I wasn’t sure if there were different menus I can use than the 2.
Tags (1)
Labels (1)
4 REPLIES 4
Sean570
in reply to: jsweatherbie
There is also "INPUT" which allows users to type something in a small textbox. as well as having users select multiple entities that exist in the explorer tree.  But that's about it. They are used like this:
STRING userInput = INPUT "Enter Tool Name."
Entity LIST tps = {}
$tps = INPUT ENTITY MULTIPLE toolpath "Select toolpaths you want to use"
Hi @jsweatherbie,
There are a few options:
Yes/No box
INT $Err = 0
$Err = QUERY "Is selection correct?"
Text entry box
STRING $UserInputText = ""
$UserInputText = INPUT “Text to display to the user.”
Selection box
INT $Err = 0
$Err = INPUT CHOICE <string list> “Text to display to the user.”
Entity Selection box
ENTITY $Ent = INPUT ENTITY <ENTITY TYPE> “Text to display to the user.”
Entity selection, allowing you to select multiple entities
ENTITY LIST $Ents={}
$Ents = INPUT ENTITY MULTIPLE <ENTITY TYPE> “Text to display to the user.”
You can also use MACRO PAUSE to allow the user to interact directly with elements of the PowerMill interface, you can then resume the macro by clicking the button on the form, you can add instructions to the macro pause form using:
MACRO PAUSE "Instructions go here"
Hope that helps
Richard
Richard Pedley
Research Engineer
Thanks this helps more then ever
jsweatherbie
//SHOWS YOU A LIST OF DRILLS
string list options={"0.531 GOLD","0.551 GOLD","0.656 GOLD","0.689 GOLD","0.812 GOLD","0.875 GOLD"}
int i = INPUT CHOICE $options "Choose your GOLD Drill?"
if $I == 0 {
FORM FEATURESELECT
MACRO PAUSE "SELECT A HOLE" + crlf
//531 GOLD DRILL
IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "C:/Users/User/AppData/Local/Autodesk/PowerMill/My-Strategies/GOLD-DRILLS/531-G-DRILL.ptf"
RENAME TOOLPATH "1" ".531-G-DRILL"
EDIT TOOLPATH ".531-G-DRILL" CALCULATE
FORM ACCEPT SFDrilling
if $I == 1 {
//551 GOLD DRILL ( NEVER-USED )
if $I == 2 {
FORM FEATURESELECT
MACRO PAUSE "SELECT A HOLE" + crlf +"AND PRESS RESUME"
//656 GOLD DRILL
IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "C:/Users/User/AppData/Local/Autodesk/PowerMill/My-Strategies/GOLD-DRILLS/656-G-DRILL.ptf"
RENAME TOOLPATH "1" ".656-G-DRILL"
EDIT TOOLPATH ".656-G-DRILL" CALCULATE
if $I == 3 {
//689 GOLD DRILL (NEVER-USED)
if $I == 4 {
FORM FEATURESELECT
//812 GOLD DRILL
IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "C:/Users/User/AppData/Local/Autodesk/PowerMill/My-Strategies/GOLD-DRILLS/812-G-DRILL.ptf"
RENAME TOOLPATH "1" ".812-G-DRILL"
EDIT TOOLPATH ".812-G-DRILL" CALCULATE
if $I == 5 {
FORM FEATURESELECT
//875 GOLD DRILL
IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI "C:/Users/User/AppData/Local/Autodesk/PowerMill/My-Strategies/GOLD-DRILLS/875-G-DRILL.ptf"
RENAME TOOLPATH "1" ".875-G-DRILL"
EDIT TOOLPATH ".875-G-DRILL" CALCULATE
FEATURESELECT CANCEL
Technology Administrators
